2001 V70 wagon...when I disconnect the battery the dome lights don't work. What is the ignition and door cycles to "wake the car up."
sledge 395
battery disconnect-reconnect, dome light don't work. Ignitio
VCA
- Year and Model: 2008 S80 T6 AWD
- Been thanked: 5 times
UEM needs a reset, methinks. Lock and unlock the car 3 times (with key in driver's door), that should reset the UEM.sledge395 wrote:2001 V70 wagon...when I disconnect the battery the dome lights don't work. What is the ignition and door cycles to "wake the car up."
sledge 395
2008 S80 T6 AWD
1999 S70 GLT
1999 S70 GLT
- Has thanked: 17 times
- Been thanked: 35 times
True...next time, when you reconnect the battery, put your key in the ignition in position II...that will keep strange electrical things from happening.
rustylowe
- Year and Model: 2001 XC70
- Has thanked: 2 times
Thanks for this! Just saved me some hassle.MadeInJapan wrote: 23 Dec 2008, 19:35 True...next time, when you reconnect the battery, put your key in the ignition in position II...that will keep strange electrical things from happening.
- 1709 Views
- 4034 Views
- 16916 Views
- 2616 Views
Last post by MadeInJapan
- 2003 Views
Last post by RickHaleParker
