heated seat drivers side bulb gone
paulstix
Post by paulstix »
Hallo volvo site,
Ive got a V70 turbo diesel estate 2.5 ltr 98 plate. The heated seat drivers side indicator bulb has gone and i can't see how to change it? Does anybody have any ideas? Also i recently did a long trip from newcastle to london and it seemed to stay on even after i turned it off. Wondered if these two probs may be connected. It hasn't seem to do it since on smaller shorter trips. thanksin advance for any help you can give me.
Paul Brown
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Paul, welcome to MVS.
I'm not sure if those bulbs have been covered here at Matthews or not. Read through this thread (it's a bit long) and if you don't see what you're looking for, post a question at the end- I know that someone who is in the know will answer you: https://www.matthewsvolvosite.com/forums ... hp?p=53440 All I know is that the Volvo part number for that particular bulb is 9148908 (a 9mm bulb) but I don't know if it's commonly available besides the dealer (you might be able to find a reference to it in the thread previously mentioned) and it looks like the entire switch will pull out but it has clasps on the underside that will have to be depressed- possibly with something flexible (a nail file?)...you'll probably want to put some tape over the flat surface that this switch goes into so you don't scratch it if you try this. Don't mind the S70 reference in the file below...the part you want is the same in your XC as the S70 (click to enlarge):
S70 Heater Switch.jpg (86.86 KiB) Viewed 759 times
895meztz94
Post by 895meztz94 »
It's easiest to take the center console out and get at them from behind. Center console comes out literally after two screws.
1999 Volvo V70 2.4 Base 207k miles and counting
2003 Saab 9-5 Linear
Thanks for that! I don't have heated seats in my S70 so would never have guessed. Here's a write-up on taking the center console out in our cars: http://volvospeed.com/Repair/SV70console.php
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
It's really easy to pop out the coinholder/ashtray bits and Presto !
paulstix
Post by paulstix »
thanks a bunch will try that soon and let you know how i get on.
paul b
