Hello. My 2000 V70 (base, manual) gives an occasional loud snap when driving, seemingly from the base of the windshield. It happens sometimes when I hit potholes, and less often when the body is torqued (ie: parking deck 90 degree turn on an incline).
The snap sounds like a rock hitting the windshield, so it startles me every time. I hear it from either the left or right side of the car.
I've had this problem with another car and the mechanic said it was a motor mount, replaced that, and I never heard it again. Could it be that, or some other worn part traveling too far, or even a cracked weld?
Thanks for any insights.
2000 V70 loud snap at base of windshield
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
FireFox31
- Has thanked: 17 times
- Been thanked: 35 times
This is a new one on me-
Does anyone know what this is?
coolfische
- Year and Model:
I have an 850 wagon, same thing happens to me, but only in the bitter cold. No engine mount problems and it goes away with the cold weather, so I never really worried about. Not that any of this helps you out too much, but I thought I'd give my 2 cents.
My 850 does the same thing. You describe it exactly too. It always startles me and you would swear a rock just chipped the windshield. I assumed it was something wrong with the dash and how it is mounted. I have all new motor mounts 500 miles ago so I don't think it is that in my case. I had a similar problem with a new Toyota it just wasn't so load. The dealer solved it by wedging some shims in somewhere in the dash.
95 850 Turbo Wagon
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
My 850 does the same thing, usually when it's below 15f.
It does scare the hell out of you. It's loud enough to make you look at the windshield to see if it actually cracked.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
VCA
- Year and Model: 2008 S80 T6 AWD
- Been thanked: 5 times
Mine did the same thing--on very hot days, with the air running full blast, as soon as the cabin cooled from "Sahara" down to "hot as Hades" I'd get that exact noise...a frighteningly loud crack. When I had the evaporator replaced, my shop reinforced the dash mounts and it never happened again.larryh wrote:It could be another broken dash assembly. Very common problem.
2008 S80 T6 AWD
1999 S70 GLT
1999 S70 GLT
Same here, but only occasionally. I haven't found anything to cause it other then temp difference, possible expansion/contraction of parts.
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
- FireFox31
Thanks, you guys are the best!
I checked my notes and this did start in March 2007; the bitter cold. The fact that I constantly forget about it probably means it goes away all summer.
Do you know exactly what needed to be reinforced, so I can point a mechanic in the right direction? I'll address it if I ever need the dash taken out.
Another question answered, another donation to MVS!
FireFox31
V70Johnson
- Year and Model:
I've owned my 2000 V70 for just over a year and a half and just recently, I've been experiencing the same darned thing. In my case, there doesn't seem to be any particular driving condition that causes it, but I have to agree, it scares the hell out of me!!! It's loud enough that I sincerely expect the windshield to crack....or worse....how 'bout EXPLODE! I'm stifled fer sure.
- 2885 Views
- 16 Replies
- 3280 Views
Last post by hammertime
- 949 Views
Last post by overtcm
- 1794 Views
- 7112 Views
Last post by Suchy101
