Bill,
I read some of your responses to similar question. (P0172 System too rich Bank 1)
my car has 120K miles (230K km). I already cleared the code before, but it keeps reappearing.
few Q's
1. How many Oxygen sensor these cars have. (some say only one, other claim 2)
2. Since these bloody parts are expensive, is that possible to clean the heads with metal brash, or chemical, for them function again.
3. Are there any other causes to which you can think of. ( I already cleaned the MAF, and checked the vacuum lines.
Appreciate reply thanks
1996 Volvo 960 P0172 OBD Code
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
1. There are two on the '96 model. From '92 to '94 there was only one.
2. I don't know of any cleaner and would not recommend a wire brush. This is how one of these units works, courtesy of HowStuffWorks:
3. Low or high fuel pressure; leaking injectors; leaking EVAP system; contaminated engine oil; oil level too high.
Bosch recommend that heated sensors are changed every 60,000 miles. Of course that increases their profit but the sensors don't last forever.
Bill.
No amount of cleaning with a wire brush is going to restore that.The oxygen sensor is positioned in the exhaust pipe and can detect rich and lean mixtures. The mechanism in most sensors involves a chemical reaction that generates a voltage (see the patents below for details). The engine's computer looks at the voltage to determine if the mixture is rich or lean, and adjusts the amount of fuel entering the engine accordingly.
The reason why the engine needs the oxygen sensor is because the amount of oxygen that the engine can pull in depends on all sorts of things, such as the altitude, the temperature of the air, the temperature of the engine, the barometric pressure, the load on the engine, etc.
When the oxygen sensor fails, the computer can no longer sense the air/fuel ratio, so it ends up guessing. Your car performs poorly and uses more fuel than it needs to.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
Bill,
thanks again for the reply. Got it.
I have one more question of this subject. I don't expect to keep the car for too long (maybe another 10K) before selling it. So it is natural I will want to get by as cheap as possible.
This site
http://www.autopartswarehouse.com/searc ... 4294965671
has variety of sensor, with big gap between the prices (I realize the axiom "you get what you paid for").
What is your opinion about the generic $42 vs. the Bosch?. ( I can solder the wire?
thanks again
This site
thanks again
- billofdurham
I agree you get what you pay for. If it lasts 10,000 miles and you have sold the car you did get what you paid for.
The reviews are good. I noticed there were none for the Bosch so they probably only sell the cheaper version which is what I would have bought.
Bill.
Bill.
Previously:
Previously:
Bill,
This outlet
http://www.car-stuff.com/store/?N=11876 ... 11921+9167
has the same parts, but cheaper. They offer 2 Universal parts. A 2 wired (USOS-2000) and a 3 wired (USOS-3000) one.
Which one would fit my car?. (I have never had to replace the O-Sensors before, so I am somewhat in the dark).
Appreciate some clarification here.
thanks
This outlet
thanks
- billofdurham
The oxygen sensors on your car are heated so you need the 3 wire version.
Bill.
Bill.
Previously:
Previously:
- 3287 Views
Last post by Sommerfeldt
- 975 Views
Last post by pgill
- 1757 Views
Last post by father ted
- 17 Replies
- 3502 Views
Last post by John850GLT
- 3010 Views
Last post by charleskennedy23
