PO133 Rear Oxygen Sensor, replaced, still getting code
jallert
Year and Model: 2007 S60R
Post by jallert »
1997 850 T5: My check engine light came on. My mechanic gave me two codes for rear oxygen sensor (PO133 for generic code). I replaced it. A day later same code came back. ANy thoughts? I did purchase and install (this time) the Bosch pigtail. Seems wierd. I have lots of extra wiring that I just spooled and tied back with a tie strap. Thanks for the help.- JA
John
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
My book shows P0133 relates to the front oxygen sensor.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
jallert
Post by jallert »
Thanks Bill. Will double check, but he was using a volvo code reader. Mine is telling me PO133. What about disconnecting battery to let things reboot? I never disconnected the battery during the install. thx
John
billofdurham
It is best to disconnect the negative battery terminal before unhooking any electronic sensor wires otherwise the computer doesn't know it's in the system.
Make sure you have your radio code, turn ignition switch to 'off', at this point I remove the key as disconnecting the battery with the ignition 'on' can damage electronics. Disconnect the battery negative lead and leave it for about 30 minutes. Reconnect the battery and take the car for a run to allow the computer to relearn.
Bill.
Previously:
pkc303
Year and Model: 1995 T-5R Yellow
Has thanked: 1 time
Been thanked: 3 times
Post by pkc303 »
I have the same problem (Code P0133), and forgot to disconnect the battery when replacing the front sensor. I tried a known good front sensor, same problem. I bought one from IPD, same problem. Volvo service man tells me to replace both sensors. So, I get a Bosch and replace rear sensor. Forgot to disconnect power from battery again. Drive around, and get code P0133.
I'm waiting 30 mins. as per last post. We will see if I get code.
My question for the last post was did it work????
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
pkc303
Has thanked: 1 time
Post by pkc303 »
Well, I tried all of the suggestions above, and to no avail. The CEL comes back on, and the code remains the same. P0133. I'm open for any suggestions.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
If you reseted code and it comes back again with new sensors,then i think it could be some vacuum leak.But if there is a vacuum leak then ecu should display codes for both sensors,front and rear. :?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
pkc303
Has thanked: 1 time
Post by pkc303 »
I'll check for a vacuum leak, and also trace the wires for bad connections. Thanks.
pkc303
Has thanked: 1 time
Post by pkc303 »
Ok, I fixed it. Our 1997 850R could not pass emissions testing. It had high HC and high CO, caused by unburned hydrocarbons.
Reading late the other night, I found a TSB number 824 dealing with a pulsation damper to damp shock waves in the fuel injection system. It's job is to reduce the shock waves in the fuel rail when the injectors open and close. These can produce the incorrect fuel flow at certain engine speeds. It goes on to say that it can affect the heated oxygen sensors (HO2S), thus our P0133 code, which points to a slow response in the O2 sensor before the cat.
Anyway our car has a vacuum line running from the vacuum tree just above the idle air controller over to the fuel damper just under where the fuel rail starts feeding the injectors. The elbow was deteriorated to the point that the line no longer held a vacuum. I have temporarily placed another line in, and it fixed the problem. After driving another 70 miles to reset the modules, no CEL, and it passed emissions test this morning. I have new rubber on the way from Volvo. I'll include pictures so that you have an idea what to look for. This was the final code of about 15 when we purchased the car two months ago.
Here's where we begin.
This is kinda the layout, but it is normally behind the fuel rail. I have it out for better visibility.
Here is the tree from which it was connected on one end.
This is the other end at the damper.
Here is the connection at the damper.
misha
Post by misha »
I'm glad that you're solved problem! :wink:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
