850 NA cams in a Turbo model
code-man850
- Year and Model: 855T '96
Has anyone heard of performance gains from switching the throttle body and cams off a N/A to a Turbo model 850?
'96 855 Turbo
K&N, H&R, Mobile 1
Its a wagon thing...
You wouldn't understand.
K&N, H&R, Mobile 1
- Has thanked: 17 times
- Been thanked: 35 times
Not sure...just have read that the NA cams are much more robust, so those running more boost than normal on their turbo engines have swapped theirs out for these.
Interesting. Any idea what they mean by robust?
Not sure if the throttle body is any different between NA and turbo. I don't think so offhand, but I'm not sure. If I remember I'll look it up in VADIS tomorrow.
~John
~John
tailor
- Year and Model: 2004 XC90 2.5T AWD
- Been thanked: 2 times
This post here resolves the issue of TB differences between the N/A and Turbo with some additional wisdom from other posters.
https://www.matthewsvolvosite.com/forums ... =1&t=14628
No idea on the cams
No idea on the cams
1994 850 Auto Turbo wagon 306000km (Sold)
2004 XC90 AWD 188000km
"Life is like a reel to reel tape recorder,
the closer you get to the end,
the faster it spins."
Abe Gottschalk
Abe Gottschalk
code-man850
My thinking on the cams idea was that the NA motor is acutally a 2.4L instead of a turbo coupled 2.3L Maybe this would be a question for IPD or something.
'96 855 Turbo
K&N, H&R, Mobile 1
K&N, H&R, Mobile 1
code-man850
What about a bored out throttle body? Any opinions on this? I wanna get a little more power out of my 855 turbo but not as far as ECU and or an expensive exhaust. Let me know.
'96 855 Turbo
K&N, H&R, Mobile 1
K&N, H&R, Mobile 1
dcovey
- Year and Model: 1998 S70 GLT5
I believe the NA cams have a longer duration, which means the valve is open longer, in order to allow the NA engine to breath as efficiently as possible.
check this site for camshaft specifications
http://1800philes.com/ianr/_superlist_grinds.html
1998 S70 GLT5
16T, White Injectors, .040 Overbore, Masterlube pre-oiler, Teflon intake manifold spacer, VMS Performance ECU, VMS rods, ARP Studs, MSD Ignition, Reverse IC piping, completely new from the firewall forward.
- 554 Views
Last post by JimBee
- 441 Views
Last post by Brucebo
- 1118 Views
Last post by dynamaniac
- 1260 Views
Last post by chrism
- 20 Replies
- 5524 Views
Last post by dikidera
