ok....I'm soliciting suggestions...
I have a 2000 XC SE 103,450 miles and the check engine light is on, actually it goes off and on....for the past year. the volvo dealer didn't find any codes, reset the light...and it came back on just before I got home. Called the dealer and they pretty much said that they didn't know what was wrong but they could start replacing things until the light stays out....that sounded expensive. Unfortunately I can't register the car in tennessee with the CEL on so I'm starting to get a little frustrated with a car that drives GREAT and shows no symptoms of anything being wrong, except the light
some history:
I bought the car last november with the check engine light, tracs, and abs light on. I had the abs module rebuilt, the tracs and abs lights went off, but not the CEL.
I have since also replaced the positive battery cable to the fuse box, and sparkplugs.
any thoughts would be appreciated, I've got nothing to lose and I like tinkering with the car
thanks
Zach
CEL from hades
- Has thanked: 17 times
- Been thanked: 35 times
Zach,
Is not being able to register the car a Nashville thing? I live in Knoxville and I register cars without the registration office ever even seeing the car...just the title- so what's up?
I would recommend that you have your diagnostic trouble codes read through your car's OBD-2 socket and post the codes here. Then we'll be able to help you.
Btw, even though this forum says XC70's, it is for the later version. Your post should be in the earlier section, so I'm moving this whole thread to that section. A ghost link will remain here so you'll be able to find the location of the new one.
Regards,
MIJ
Regards,
MIJ
unfortunately, in nashville before I can go to the dmv, I need to get through emissions...and emissions won't talk to you if you have a check engine light on...
the crazy / frustrating thing about this whole adventure is the dealer says that there are no codes in the car's memory (I bought an obd II reader and it also says no codes) is it possible for the light to pop on without storing a code?
2000 V70 xc se
1986 FJ60
2002 R1150 GS Adventure
1986 FJ60
- Year and Model: Many Volvos
- Been thanked: 76 times
I wonder if the problem is a wiring problem to the instrument cluster? I don't have the schematics for a 2000 but on a '99 the CEL wire is Brown/White and it goes to pin 11 on the 16 pin cluster connector.
db130
- Year and Model: 2002 V70 T5
and are we sure that we are not talking about the "SERVICE" light aka the service reminder light and not the "CHECK ENGINE" light?
if there are truly no codes stored, why not just pull the bulb for the check engine light?
2002 V70 T5 169k
2002 V70 NA 249k
2006 Mini Cooper S 90k
2002 V70 NA 249k
yeah, it's the CEL, I have a MUCH better relationship with the service light...
I would be happy to pull the bulb, or use a little black tape on the sucker, however when I brought the car into emissions they said no dice the check engine light is on, I asked if it had a code associated with it and they said nope, but it's on and you gotta fix it in order to pass. so I cleared the light and went back, and they said I hadn't let a full driving cycle run before bringing it in, so I had to drive around some...needless to say the CEL came back on. It's getting close to being funny...not yet but close
zach
zach
2000 V70 xc se
1986 FJ60
1986 FJ60
that's an interesting idea...I might need to poke around some.Ozark Lee wrote:I wonder if the problem is a wiring problem to the instrument cluster? I don't have the schematics for a 2000 but on a '99 the CEL wire is Brown/White and it goes to pin 11 on the 16 pin cluster connector.
the trick is I can clear it (for a while) with the OBDII reader or diconnecting the battery...
2000 V70 xc se
1986 FJ60
1986 FJ60
db130
Back in March 2008, I had a P0422 code that would come back within 75 miles of having the CEL reset(due to 2 "lazy" o2 sensors). I got the emissions system to report as "ready" in 60 miles, immediately had the car inspected(and it passed since the OBDII system indicated that it was working 100%), and the CEL came back on my way home from the inspection station.
How many miles can you drive the car after the CEL has been reset before the CEL comes back on?
2002 V70 T5 169k
2002 V70 NA 249k
2002 V70 NA 249k
60-80 miles....db130 wrote:Back in March 2008, I had a P0422 code that would come back within 75 miles of having the CEL reset(due to 2 "lazy" o2 sensors). I got the emissions system to report as "ready" in 60 miles, immediately had the car inspected(and it passed since the OBDII system indicated that it was working 100%), and the CEL came back on my way home from the inspection station.
that's interesting...did you ever do anything with the O2 sensors?
2000 V70 xc se
1986 FJ60
1986 FJ60
db130
actually, yes....
i replaced them in my driveway with new ones on the same day right after i got the inspection sticker. i now have a OBDII scanner that can check for OBDII system "readiness":
http://forums.swedespeed.com/zerothread?id=102950
my suggestion to you would be(just so we can get your car registered first):
1) buy such a scanner that can scan for readiness
2) reset CEL, check after 50-60 miles if the OBDII OBD monitors come up as ready for testing.
3) get car inspected ASAP before the CEL comes back on.
2002 V70 T5 169k
2002 V70 NA 249k
2002 V70 NA 249k
- 1045 Views
Last post by Jeremyduvekot
- 16 Replies
- 3309 Views
Last post by styoung94
- 545 Views
Last post by fiore67
- 11 Replies
- 2313 Views
Last post by Derekw66
- 958 Views
Last post by iruleyounow
