IPD sale Volvo Parts
Did you know? 🤔
440 -95 B18U Problems with cold start + bad idle
Discussion and advice for 440, 460, 480 owners.
1986 - 1997 440
1986 - 1997 460
1986 - 1997 480
Quickie2
Year and Model: 440 -95 B18U
Has thanked: 0
Been thanked: 0
Quickie2
Re: 440 -95 B18U Problems with cold start + bad idle
Post by Quickie2 » Mon Apr 27, 2009 4:50 am
Finally! :D I am 99.99% sure I've found my problem. My TPS is probably giving me theese problems.
I have one last question, the volvo dealer doesn't sell the tps separatly and I wonder It's even possible to just replace the sensor only??
masse
Year and Model: 480 88
Has thanked: 0
Been thanked: 0
masse
Post by masse » Sun Mar 07, 2010 8:28 am
billofdurham wrote:Welcome to Matthew's Volvo Site.
4-1-1 is Throttle Position Sensor (TPS) signal error. Possible causes are wiring fault; accelerator cable adjustment; faulty TPS or ECM fault.
Check the wiring to the TPS then, with a voltmeter, check for voltage at the plug.
Values should be as in the attached.
Bill.
I have a 480 -88 and i cant find a obd unit ...
where did you find the voltage values for the tpsensor?
I need the values for all the sensors since i cant find a obd...
masse
billofdurham
Year and Model: 855, 1995
Has thanked: 0
billofdurham
Post by billofdurham » Mon Mar 08, 2010 3:54 pm
The OBD was first fitted to the 1990 cars.
I shall post the values for you but it will take time to collate them so please be patient.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
masse
Has thanked: 0
Been thanked: 0
masse
Post by masse » Mon Mar 08, 2010 4:47 pm
Thank you very much! :)
billofdurham
Has thanked: 0
billofdurham
Post by billofdurham » Tue Mar 09, 2010 11:38 am
I think I have covered most of the engine sensors, but if there is anything I have missed that you need let me know.
480 sensors.pdf
(2.11 MiB) Downloaded 199 times
Bill.
Previously:
