s40 2001 Comp. Dead?
This topic is in the MVS Volvo Repair Database » S40 2001 Computer Dead?
kojack1072
Year and Model: s40 2001
Post by kojack1072 »
Hi guys, I'm appealing to you again, I changed my plugs and wires and they were working fabulously for about fifty miles. Today when I went to start my car nothing happened, not even a crank except a trouble code #602 if you can help once again I will greatly appreciate it, thanks. :(
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Are you saying P0602 (Control Module- permanent fault)?
If so, you might just have a dead battery, not allowing any connection to your computer or something else...try pulling your computer (if your battery is good) and reseating it- make sure your key is out of the ignition. Otherwise, bad battery terminal wires or corrosion. It is actually very rare that the ECU up and becomes a ghost.
kojack1072
Can you tell me where is the comp. located?
01 S40 ECU Location.jpg (24.45 KiB) Viewed 2742 times
kojack1072
Thanks alot, I'll try that.
kojack1072
I tried that but, it didnt work. Then I had the car towed to my local Volvo dealer, but the service guy said that I had to get a new computer which cost $1,035.00, then he would test my system @ $120.00 an hour. He further said there would be no guarentee on the work that was being done. A friend of mine said to check the cam solenoid adjuster to see if that was defective. Can you help me to find a way to test it. I really need some help in fixing this vehicle cheaply, cause I've only had it for two months and I've yet had the chance to enjoy it without putting money into it. Thank you in advance for what ever help you can offer.
I don't know of a Cam solenoid adjuster...but maybe a cam position sensor? (also known as the impulse sensor) http://www.eeuroparts.com/Main/PartDeta ... id=1270603 If this is bad, your car won't start. Because it doesn't start, also, your car won't read the code for it. It is on the front side of the engine close to the firewall (on your model S40):
01 S40 Impulse Sensor.jpg (121.63 KiB) Viewed 2740 times
tsuxjfreak
Year and Model: 01 s40
Post by tsuxjfreak »
Hi there. If you find that it is your ecm gone bad, i have a 2001 s40 that i am parting out and you can have the computer for $300 if you want it. I can have it out and shipped today so just let me know.
