IPD sale Volvo Parts
Did you know? 🤔
volvo 440 -95 Where is the inlet manifold gasket?
Discussion and advice for 440, 460, 480 owners.
1986 - 1997 440
1986 - 1997 460
1986 - 1997 480
Quickie2
Year and Model: 440 -95 B18U
Has thanked: 0
Been thanked: 0
Quickie2
Post by Quickie2 » Tue Feb 24, 2009 6:16 am
Hello,
I have a volvo 440 B18U engine. Does anyone where my inlet manifold gasket is? 8)
billofdurham
Year and Model: 855, 1995
Has thanked: 0
billofdurham
Re: volvo 440 -95 Where is the inlet manifold gasket?
Post by billofdurham » Tue Feb 24, 2009 12:15 pm
How did you lose that? :lol:
It is a combined gasket for the inlet and exhaust manifolds between the cylinder head and the manifolds. To access it you would need to remove both manifolds.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Quickie2
Has thanked: 0
Been thanked: 0
Quickie2
Post by Quickie2 » Thu Feb 26, 2009 2:43 am
billofdurham wrote:How did you lose that? :lol:
Bill.
It kind of flew away, you know my engine got some juice :)
Ok, I'm not a pro, when I look back there I see a lot of gaskets. You have a picture or something? Is It hard to change It?
billofdurham
Has thanked: 0
billofdurham
Post by billofdurham » Thu Feb 26, 2009 3:35 pm
The first attachment is of the manifolds showing the combined gasket at #10.
440 inlet_exhaust manifolds.pdf
(305.06 KiB) Downloaded 286 times
The other attachments give the procedure for replacing the manifold gaskets. It isn't a job to be started without pointing out the possible pitfalls. The 'preliminary operations' point out that the bolts and nuts must be treated with a rust solvent. This is imperative as they have probably been in there for 13 - 14 years and will be well rusted. If they snap as you remove them the cylinder head will have to be removed to have the broken bolts taken out by a machine shop. I speak from first hand experience as I have just replaced the manifold gasket on my son's 17 year old Talbot Express motor home. I broke 3 bolts which had been soaked in penetrating oil!!
You will have to decide if you are able to do this when you read the instructions in the attachments.
Remove refit air inlet and SPI.pdf
(957.18 KiB) Downloaded 184 times
Remove_refit manifolds.pdf
(638.1 KiB) Downloaded 224 times
Specifications.pdf
(637.91 KiB) Downloaded 171 times
I hope this will help you to make up your mind.
Bill.
Previously:
Quickie2
Has thanked: 0
Been thanked: 0
Quickie2
Post by Quickie2 » Wed Mar 04, 2009 3:49 am
Wow, a lot of good information. I now need somehow to make sure It really is leaking :?
May I ask you where you get all this info from?
billofdurham
Has thanked: 0
billofdurham
Post by billofdurham » Wed Mar 04, 2009 3:50 pm
The information on replacing the gaskets is from the VADIS discs. Other information is from a fairly large collection of books covering Volvo repairs.
To check the inlet manifold gasket buy a tin of carburettor cleaner, start the engine and spray the carb cleaner around the gasket. If it is leaking the engine will surge as it draws the cleaner in. The other method is to spray water on the gasket. If it is leaking the engine will falter.
Bill.
Previously:
Quickie2
Has thanked: 0
Been thanked: 0
Quickie2
Post by Quickie2 » Thu Apr 09, 2009 12:35 am
So, I've finally got my new gasket. But I have one last question before I get going, Since the gasket has 2 different sides. One side is made of metal and the opposite side is made of the usual paper sort of material. So which side should be mounted against the engine block? I have a feeling of that the metal side should but I want to be sure before I continue.
Thanks in advance 8)
billofdurham
Has thanked: 0
billofdurham
Post by billofdurham » Thu Apr 09, 2009 12:09 pm
Correct.
The answer is in the attachment remove_refit manifolds.pdf.
Bill.
Previously:
Quickie2
Has thanked: 0
Been thanked: 0
Quickie2
Post by Quickie2 » Fri Apr 10, 2009 11:53 am
Ok, I haven't seen that.
But now I'm a bit confused, should the metal be against the manifold or the engine? Sorry:?
The attachment says against the manifold but I asked if It should be against the engine and you answered Correct. :?:
billofdurham
Has thanked: 0
billofdurham
Post by billofdurham » Fri Apr 10, 2009 12:31 pm
That was a test to see if either of us actually read things properly. :?
My mistake - the steel side does go to the manifold.
Bill.
Previously:
