S40 Shifter light
fuzzytice
Year and Model: 2001 S40
Post by fuzzytice »
Hello, my first time here. Can anyone give me info on a replacement bulb for a 01 S40 Shifter indicator bulb ? Not the bulb in the dash but the one that shows what gear you have placed the car in.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Welcome to MVS.
First of all you'll need to remove the center console panel:
S40 Center Console Removal.jpg (45.95 KiB) Viewed 8232 times
Next, follow the last part of the instructions in the file below:
S40 Interior Bulb Replacement.pdf
(295.6 KiB) Downloaded 2426 times
I am also adding the how-to for the front center console section if you need to also replace the mode light in the gear shift panel:
S40 Front Center Console Removal.pdf
(21.8 KiB) Downloaded 1832 times
AlienJulius
Year and Model: 2004 s40
Post by AlienJulius »
Hi i have an 04 S40 and spilled soda on the shifter, now the shift-lock sticks. how do i get at it to clean it out?
thanks!
-Allen
chitin
Year and Model: V40, 1999
Post by chitin »
Just replaced mine and took some pictures, hope it helps other members.
My car is 1999 V40 2.0 (RHD so light bulb is located on right side)
Loosen the only screw, and pull and slide the panel out.
The bulb holder is located underneath the 'N' position, slip your fingers inside the console and pull it out.
I don't know the part number but this is how the bulb looks and its size. I wrapped the bulb with tissue paper and pull it out with a plier.
fcth
Year and Model: 2006 S60
Has thanked: 1 time
Post by fcth »
Thanks for the info. Just replaced the one in my 2003 S40, and this info was a big help.
I used a C&K Components 1.90120.0120000 bulb which I ordered from Digikey: http://www.digikey.com/product-search/e ... maction=on (watch their shipping, anything other than USPS is really expensive.)
To get to the light, I removed the side panel like in chitin's photo, as well as the piece of plastic around the shifter so that I could see what I was doing. You can get to that by removing the rubber tray in front of the shifter (it just lifts off) and then releasing the two plastic clips underneath it. Those were pretty stiff and I had to pry them with a screw driver. I did them one at a time, which makes it easier since the piece can slide a bit. Once they are off you can just lift the cover out so you can see where the bulb socket is.
notalanm
Year and Model: S40 2000
Post by notalanm »
fcth wrote:Just replaced the one in my 2003 S40, and this info was a big help.
Do you know if this bulb is the same for a 2000 S40? I cannot really tell from what's on the digikey website. Thanks!
superdeluxe
Year and Model: 2003 s40
Post by superdeluxe »
just replaced this shifter indicator bulb and the cigarette lighter perimeter light in a 2003 volvo s40. the bulb used for both was the 2721 or 2721LL available at oreilys auto part stores (usa) $5usd for 2 incandescent bulbs. the socket type is t5. the fit and length was a perfect match to oem.
