Hi,
I am new to this forum so if I mess up please be patient.
My 1995 850 Turbo has lost its dashboard lights. I took it to my mechanic who did something that made the lights come on.
It lasted one day. I took it back and his answer was take it to a Volvo dealer. Does anybody have any suggestions?
Thanks.
Bald Eagle.
Volvo 850 1995 dashboard lights are out
Bald eagle
- Year and Model: 1995 850 tur
meteg
- Year and Model: 2007 V70 2.0T
hello,
%90 the electrical portion of the ignition switch is bad.its a common occurence in 850 series.replacing the ignition switch with a used or new one will solve the problem.
good luck
good luck
mine was the dimmer switch....find one in salvage yard...they are expensive
'95 850 Turbo
03 Cummins Turbo Diesel
02 Paint 1 horse power hay burner
07 Paint 1 horse power hay Burner
08 Palomino 1 horse power hay burner
Bald eagle
Thank you for your suggestions.
Will try the easiest first and if that does not work
will try the other..
Will post the results,
Thanks again,
Bald Eagle
Thanks again,
Bald Eagle
