S90 1997 Powerseat rail Jammed
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
tompete
Year and Model: S90 1997
Post by tompete »
Drivers side / rail on right side is jammed. Can I remove the seat To get to the rail w/out causing any air bags or anything else to go off. Any manuals that will explain how ? Also my air bag on passengers side rattles badly, is it safe to look into that area or best to let dealer do it?
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Your car is fitted with the Side Impact Protection System (SIPS) which needs to be immobilized before removing the seat. Before disconnecting the battery you must have the radio code.
S90 SIPS.pdf
(463.05 KiB) Downloaded 128 times
Further instructions on removing the seat, seat rails and locking the seat belt tensioner are in the following attachments:
S90 seat removal.pdf
(377.83 KiB) Downloaded 192 times
S90 seat removal 2.pdf
(378.22 KiB) Downloaded 114 times
Are you sure it is the passenger air bag that is rattling? You must judge your own ability to check this when you have read the instructions:
S90 airbag.pdf
(446.31 KiB) Downloaded 166 times
All instructions are taken from VADIS.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
tompete
Post by tompete »
Thanx for info on jammed seat. I copied all attachments and will attempt fixes . seat & air bag. Bought dvd of Volvo manuals also. Thanx again for reply 8)
