1992 240 Wagon Rear Wiper and Washer
craigsan42
- Year and Model: 240 1992
Neither the rear window wiper or washer are working on my '92 240 wagon. I would appreciate advice on steps to take to troubleshoot this. The fuses seem okay. Although this is my first time to check the fuses (just bought this 240 wagon). They look much different from the fuses on my previous 740 wagon. I assume if the fuses are bad that the metal strip spanning the fuse cylinder would be broken. Thanks.
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
It is possible that the wires have been damaged where they come away from the roof into the tailgate. This is fairly common.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
Paul240480
- Year and Model: V70SE Auto. V70T5SE.
The last post is spot on! Open the tailgate & look into each hinge. You'll see split wires if this is the case. Two remedies:
1) Buy new wiring looms, not expensive.
2) Cheat! loosen the hinge bolts a couple of turns. Snip any still good wires & pull through into roof void (having carefully released the roof lining).
3) Rejoin the wires direct from source to boot lid making an unsighty, but effective loop, like this:
Can be tidyed uo with with a split piece of conduit.
Good luck
Good luck
Paul240480
http://www.gitessouthbrittany.com
- 19 Replies
- 3854 Views
Last post by jvl
- 2160 Views
Last post by Teddy1975
- 36 Replies
- 24974 Views
Last post by StickyPocket
- 1299 Views
Last post by RickHaleParker
- 2159 Views
Last post by Rattnalle
