My heater blower in my s40 turbo blows intermitently from high to low. Doesn't matter what the temperature knob is set at. Low to high. High to low. Back and forth. Really annoying!
My mechanic replaced the relay because at one point the blower would not turn off. Then it just stoped, The relay replacement got the blower working again but did not fix the blower from blowing high and low. He told the next step was to replace the knob that regulates the speed. He also informed that the whole panel with the three knobs(speed,temperature,direction) was an integrated system and the whole thing needed to be replaced. I'm a little hesitant and wondering if there might be some other resolution to this problem as the price just for the integrated panel is $800.00 not including labor. Is there a cheaper fix for this problem?
Tony G.
HEATER BLOWER PROBLEM IN 2002 VOLVO S40 TURBO
- Has thanked: 17 times
- Been thanked: 35 times
Hey Tony G.
Welcome to MVS.
I'm not sure about your unit in your car.
You might get an answer here but maybe not.
If not, then try the same question over on www.s40concepts.net/newforum/
Regards,
MIJ
Welcome to MVS.
Regards,
MIJ
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
This is usually the heater resistor starting to break down and is a common problem on that age S/V40.
As MIJ gave you one link to S40concepts I shall try to go one better and give you the link to the repair: http://s40concepts.net/forum/index.php? ... 27061b0bb7
One of the causes of the failure, apparently, is allowing the cabin filter to become choked making the fan work harder.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- 3165 Views
Last post by KArthur1
- 1721 Views
Last post by danoneason
- 2033 Views
Last post by 90 Beater
- 1505 Views
Last post by alschnertz
- 46 Replies
- 12923 Views
Last post by 93Regina
