S60 AWD 2002 Rear shocks
therdes
Post by therdes »
I need new rear shocks on my 2002 S60 AWD ( 190,000 km) Is replacing the shocks a DIY job? Will I need a coil spring compressor to do this job? Can anyone provide tips on the procedure to do this job?
Thanks,
Tom H
Ontario, Canada
2002 S60 AWD
190,000 km
Tom H.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Being a AWD you have Nivomat (self-leveling) shocks which are expensive an only made by/for Volvo, you are sort of stuck on what you can replace with. From what I understand there are no other alternatives. It's however not a difficult job to do:
02 S60 AWD Shock Replacement.pdf
(931.73 KiB) Downloaded 1368 times
therdes
Post by therdes »
Hi MadeInJapan,
Thanks for your excellent response. The PDF file is very helpful. Can you provide the torque specs for the bolts on the bottom and top of the shocks. Thanks very much!
Tom H.
here you go!
S60 troque specs.pdf
(3.03 KiB) Downloaded 561 times
If you don't know the conversion from Nm's to ft lbs this on-line converter should help: http://www.onlineconverter.co.uk/index. ... ors&cat=12 Angle tightening means just that- after your initial torquing you go so many degrees.
therdes
Post by therdes »
Mi Made in Japan. I replaced my shocks yesterday....it took less than 1 hr per wheel. FYI, on this model they are not Nivomats, just plain Sachs shocks (CAN $140 ea. @Autopartsway.ca) . I found a website with step by step photos of how to replace the shocks on this model - very helpful!; see the link attached from another Volvo help website....
http://images.google.ca/imgres?imgurl=h ... ie%3DUTF-8
best regards,
Tom H.
Ontario, Canada
2002 Volvo S60 AWD 190,000 km
2007 Volvo XC 70 63,000 km
Tom H.
Thanks for posting back!
Great write-up! Glad it wasn't too bad. Thought all AWD shocks were Nivomats...learn something everyday.
George
Year and Model: V70 2002
Post by George »
Hello therdes, 8 months ago you posted questions about your rear shocks. Had the fronts been done? Was one or both leaking? Love to hear details. Thanks, George
billr99
Year and Model: 2002 V70XC
Post by billr99 »
MadeInJapan wrote:Thanks for posting back!
Just an FYI, but my '02 XC's rear shocks were also standard old Sachs tubes. Same PN as the '02 AWD V70 and S60 as well.
Cheers,
Bill
'05 XC70 (Lava Sand)-235K kms to-date
'02 V70XC (Ash Gray)-375K kms to-date
And a whole tonne of other Euro stuff (Volvo (8), VW (6), MB (1), Audi (3), BMW (2), SAAB (5), Land Rover (4), Porsche (2), Opel (1), MG (1), Mini (2), Sunbeam (1))
bschlage
Year and Model: 2001 S60 T5
Post by bschlage »
I have a 2001 S60 FWD. Is the procedure to change the shocks any different, and do I need the self leveling shocks mentioned prior in this post? Thanks!
DEMonte1997
Year and Model: 2003 V70
Post by DEMonte1997 »
Any tips for getting at the top nuts on the AWD wagons? Wish my V70 was as easy as the S60 in that regard. :(
2003 V70 | 2001 Regal turbo | 2002 Sierra Denali
