IPD sale Volvo Parts
Did you know? 🤔
440 B1U -95 How to replace timing belt?
Discussion and advice for 440, 460, 480 owners.
1986 - 1997 440
1986 - 1997 460
1986 - 1997 480
Quickie2
Year and Model: 440 -95 B18U
Has thanked: 0
Been thanked: 0
Quickie2
Post by Quickie2 » Fri Apr 03, 2009 4:22 pm
Next step for me is to change the timing belt on my car, god knows when It was done last time. Does anyone have some good instructions for this, do I need any special tool?
thanks in advance.
billofdurham
Year and Model: 855, 1995
Has thanked: 0
billofdurham
Re: 440 B1U -95 How to replace timing belt?
Post by billofdurham » Sat Apr 04, 2009 3:30 pm
Special tools are listed in the attached instructions. The only one that may cause a problem is the tension gauge.
The belt should be replaced every 60,000 miles (96,560.64kms give or take a centimetre :) ) or 72 months, whichever occurs first.
440 T Belt replacement.pdf
(612.1 KiB) Downloaded 1310 times
440 T Belt replacement2.pdf
(560.67 KiB) Downloaded 934 times
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Quickie2
Has thanked: 0
Been thanked: 0
Quickie2
Post by Quickie2 » Sun Apr 05, 2009 11:39 am
Thanks mate, your service is amazing. I've recommended you to a swedish forum :D
My replacement belt doesn't have any markings, how do I know where to place the belt? :?
Another question: this hole for locking the crankshaft with 8mm bolt, Is It to the right of oil dip stick, there I can find a torx bolt. Is it this one? :|
billofdurham
Has thanked: 0
billofdurham
Post by billofdurham » Sun Apr 05, 2009 3:41 pm
I have checked with another book which does not mention marks on the belt and I have never changed a timing belt that did need to be aligned with the timing marks.
The hole for the timing pin is covered by a plug so I doubt that it will be a torx bolt.
Bill.
Previously:
Quickie2
Has thanked: 0
Been thanked: 0
Quickie2
Post by Quickie2 » Mon Apr 06, 2009 4:10 am
Ok, that's good.
I can't find this plug, you have a picture or something showing where It is? :shock:
Another thing, On the gearbox housing there are some marks that should be aligned with a mark on the flywheel. The marking on the gearbox is from 0 degrees to 8 degrees. There are 2 line for 0 degrees and then 3 lines for 8 degrees. Where should the marking be? Or maybe this doesn't matter as I lock the crankshaft? 8)
billofdurham
Has thanked: 0
billofdurham
Post by billofdurham » Mon Apr 06, 2009 12:21 pm
The only picture I have is on the attachment above at #4. The location in the attachment is borne out by the other book I have as
Remove the plug near the dipstick tube.
There are no pictures at all in that book.
440 timing plug.pdf
(372.31 KiB) Downloaded 548 times
The only other thing I have been able to find is in VADIS parts. Looking at the engine assembly it is possible that the plug is #8 as it is near the dipstick tube and lying at the right angle to be #4 in the original picture.
If you are locking the crankshaft the positions of the marks on the flywheel and gearbox should not change.
Bill.
Previously:
