I was wondering if anyone knew where the level sensor is located. I was thinking about lowering. Can I adjust the rear and change the front springs? I am only considering 20-30mm. The lowering kits I see are only offered for xc90s without the automatic leveling system.
Thanks,
Mike
xc90 2006 suspension level sonsor location
- Has thanked: 17 times
- Been thanked: 35 times
I believe your car has to tip 45 degrees before the shut-off valve stops gas from leaving your gas tank (a safety measure if you're even in an accident w/ roll-over. Therefore, lowering your car should not have any impact on your level sensor.
mjl99
- Year and Model: 2006 XC90 V8
Thanks for your reply MadeInJapan. The level sensor is for keeping the rear up when weight is added. This was a feature with a v8 7 passenger.
2006 XC90 V8 silver/graphite
2004 V40 1.9T silver/graphite
Okay- we're talking about 2 different things then- part of the Nivomat rear shocks or self-leveling shocks. I have not idea then- Hopefully someone will chime in.
mjl99
I have done some reading and it seems that the rear shocks may be Nivamat self leveling shocks. I saw somewhere that they sold a level sensor. That is what got me thinking about lowering. If they are Nivamats is there a way to adjust the ride hight?
I'm not sure but I'm thinking that different, shorter springs will do it- Nivomat or not. You need to ask some other XC90 AWD members to confirm this. If you get on luck here, try over on www.xc70.com I know it says it's an xc70 forum but there are many xc90 owners there in the know as well.
- 3699 Views
Last post by cuhfs
- 5540 Views
Last post by ggleavitt
- 268 Views
- 12 Replies
- 3345 Views
Last post by RickHaleParker
- 1348 Views
Last post by cuhfs
