Power seats on both sides showing same symptom - will recline further but won't come back up. Push the switch to put seat back forward and you can hear it engage, but seems to be jammed. Has power seats with memory. Car came from an estate and wasn't used very much for about three years. Any comments appreciated - need to let son take it back to school on Monday!!
Checked the codes - 331 on the drivers side - wire to motor 1 disconnected - motor 1 is the relciner motor. Passenger side is showing 111 - no code - but same problem.
Any problem if I disconnect the plug to the motor and jump a 12 volt source to get the back up?
95 855 27k Power seats reclined, won't come back up
NC_Volvo_owner
- Year and Model:
vlvman
- Year and Model: 04 S60R 94 850T 89
Fault code read-out (1995 and earlier models)
With ingition switched off, unclip the test lead from the holder and insert it in proper test socket.
Have paper and pen ready to write down codes
With test lead inserted turn ingition switch to position 2 (run) and press button on diagnostic unit for one second. First code will be displayed.
Push button for one second and second code will be shown.
Repeat until first code is displayed again.
To clear codes
Note:The fault codes cannot be deleted until all of them have been displayed at least once, and the first one is displayed again,
With test lead inserted in proper test socket, and ingition switched to position 2, press button and hold down for 5 seconds. Release the button and after 3 seconds the led will light. When the led lights press and hold down button for five seconds then release it, the led will go out. Turn ingition switch off.
Resetting service reminder light (1995 models and earlier models)
VDO instrument cluster
Turn ingition switch to position 2. Insert test lead into socket A7. Press button 4 times, briefly but firmly. When the led lights and stays light, the system is ready for manual code input. It is now time to enter code 151. To do this press the test button once and release it; wait for the led to light again, then press the button 5 times. When the led lights again, press the button once. When the led flashes several times in succession, the code has been successfully entered and the service light reset.
B6-Electrically Operated Seat
Note on Fault code read-out: Insert the test lead in socket B6. Press any button on seat control panel, keep it pressed and at same time turn ingition switch to position 2. Then continue as usual with fault code read-out.
111 No fault detected
112 Signal position sensor, motor 1, absent or faulty
121 Signal position sensor, motor 2, absent or faulty
122 Signal position sensor, motor 3, absent or faulty
211 Signal position sensor, motor 4, absent or faulty
123 Motor 1 functions although equivalent button not activated
131 Motor 2 functions although equivalent button not activated
132 Motor 3 functions although equivalent button not activated
133 Motor 4 functions although equivalent button not activated
323 Fault in stored memory position 1
322 Fault in stored memory position 2
333 Fault in stored memory position 3
331 Lead disconnected motor 1*
332 Lead disconnected motor 2*
333 Lead disconnected motor 3*
114 Lead disconnected motor 4*
143 Motor 1 turns in wrong direction
144 Motor 2 turns in wrong direction
214 Motor 3 turns in wrong direction
224 Motor 4 turns in wrong direction
414 Faulty end position calibration
*These codes may also be displayed if the motors are not allowed to reach their limit stops.
To clear codes
wheelsup
- Year and Model:
- Has thanked: 16 times
- Been thanked: 22 times
The easiest way to get them back up quickly is to snip the metal clips holding the leather on the bottom of the seats (in the back) and some pliers on the metal bar running horizontally across the seat back on the bottom. That is what the motor turns to move the gear to raise the seat. You can turn it by yourself and rotate the seat back up.
- Year and Model: Many Volvos
- Been thanked: 76 times
Another good writeup is here:
http://volvoforums.com/forum/showthread.php?t=16364
The hog rings are a PITA to crimp back on and I just used small ty-wraps to re-secure the upholstery when I put my seat bottoms back together. It has held up just fine.
_HighVoltage_
- Year and Model: 1994 850 NA
Sorry if I am hi-jacking this thread but I have a related problem.
My power seat works in almost every direction...except for the backrest. It won't move forward or backward. I can hear a click, when I push the button but that's it.
I haven't tried diagnostics yet...but from the sounds of it, what do you think it is? Wiring, or motor related?
If it is the seat recline function it is almost always the mechanical cable that is featured in the links above.what do you think it is? Wiring, or motor related?
- 1348 Views
Last post by 1337
- 17 Replies
- 5511 Views
Last post by shiloh51933
- 3857 Views
Last post by Terrible2004s80
- 678 Views
Last post by billwann
- 481 Views
