what or where is the "main relay" in fuel injected 240dl
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
jravionics
Year and Model: 1990
Post by jravionics »
Hello to all,
I have a 90 240dl that ran and just quit. Fuel pump relay has no power to it and fuzes all are OK. I tried to find the "main relay" on the schematic but can't quite find it.
thanks for the help.
jim
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Did you check the 25 amp blade fuse on the left wheel housing next to the ignition coil?
As far as I know there isn't a 'main relay' on the 240.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
jravionics
hi Bill,
there is a 30 amp holder flopping around near the battery but I will go outside tomorrow and see if there are any other fuses floating around.
I just saw the schematic and realized that the relay they talk about is the fuel pump relay. It is not cutting in and I tried to bypass it and got no +12v but now that I figured out what the drawing is, I will try some point to point and see where I loose it. Had a lot of bad connectors with this old thing so thats what I suspect. I will let you know what I find.
jim
