Did you know? 🤔
Have you refurbished your injectors? Topic is solved
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 617 times
Been thanked: 260 times
United States of America
matthew1
Post by matthew1 » Fri Apr 17, 2009 11:21 am
Does this have a good cost/benefit ratio?
Is it delicate/high FUBAR possibility?
Also -> Amazon link
. Click that when you go to buy something on Amazon and MVS gets a kickback.
1997 850 T5, MSD ignition coil, Hallman manual boost controller, injectors, R bumper, OMP strut brace [gone]
MadeInJapan
Has thanked: 7 times
Been thanked: 25 times
MadeInJapan
Re: Have you refurbished your injectors?
Post by MadeInJapan » Fri Apr 17, 2009 4:14 pm
I've never done it but some swear by it, especially if they have "tuned" their car. I figure high octane gas and the occasional bottle of Chevron Techron keeps them clean.
tjts1
Year and Model: 96 855 NA 5 speed
Has thanked: 0
Been thanked: 3 times
tjts1
Post by tjts1 » Fri Apr 17, 2009 8:47 pm
I like to DIY this procedure on my injectors at home.
http://www.fordfuelinjection.com/?p=82
You'll be amazed at the crap that comes out when you backflush an injector.
Ambitious but rubbish
sleddriver
Year and Model: 1998 V70 T5
Has thanked: 11 times
Been thanked: 12 times
sleddriver
Post by sleddriver » Wed Sep 14, 2016 4:41 pm
Anyone here have any updated information? Unfortunately, this post didn't go very far. But now that these cars are even older, perhaps a simple flush + o-ring replacement is called for.
M1 10W-30 HM
oragex
Year and Model: S60 2003
Has thanked: 99 times
Been thanked: 290 times
Canada
oragex
Post by oragex » Wed Sep 14, 2016 5:54 pm
Having the injectors in an ultrasonic bath is a must every 80K miles and even sooner. Any gasoline will leave a varnish inside the injector which will reduce the flow and change the pattern and significantly decrease the mpg. Especially true if the car was most of the time driven below 3000rpm. The filter basket on the injector might be perfectly clean, is the nozzle that has varnish build up.
Side note, only a ultrasonic bath can remove this varnish, no 'injector cleaner' sold in stores can help.
sleddriver
sleddriver
Post by sleddriver » Wed Sep 14, 2016 8:45 pm
80K, eh? Geeze...wonder how they look after 214,500? Never been off the manifold either. Thought I'd at least replace the o-rings & other gaskets.
I wonder where I could get this done locally, or at least within the state of Tx to minimize car downtime?
M1 10W-30 HM
matthew1
Site Admin
matthew1
Re: Have you refurbished your injectors?  Topic is solved
Post by matthew1 » Thu Sep 15, 2016 10:19 am
Here's a post with information on DIY injector cleaning with Seafoam.
Followup: I did soak my orange injectors in Seafoam overnight some time after that post, around summer 2012, and have had good results*. I'll do it again.
* read: outside of doing this on a statistically relevant fleet of identical cars (100+), my summary is that yes it works... fuel economy and power were as good as ever, or better, after this, and my 850 did not blow up/fall apart/catch on fire
Also -> Amazon link
sleddriver
sleddriver
Post by sleddriver » Thu Sep 15, 2016 10:57 am
Thanks Matt. I used BG's fuel injector cleaning solution + their jig that hooks straight up to the injector rail and powers the car for about 20min, on my previous SAAB 900T. I recall it made quite a difference. Also cleaned out the combustion chamber.
I might go this route again, except this time I would first remove the injectors, replace the screens & seals, backflush, and THEN do the BG soln cleaning. After all, if mine were in such bad shape, the car would stumble, choke, shake, and spit and even worse under boost. It does none of that. Further, the sled sees regular use. It's my DD, not a weekend car or Summer car by any means.
This will make for an interesting investigation......
M1 10W-30 HM
matthew1
Site Admin
matthew1
Post by matthew1 » Thu Sep 15, 2016 11:06 am
sleddriver wrote:Thanks Matt. I used BG's fuel injector cleaning solution + their jig that hooks straight up to the injector rail and powers the car for about 20min...
:shock: wow that's pretty cool, Sled. Hadn't heard about it.
But yea, backflushing before that makes much sense. Otherwise you're pushing insolvent debris particles the same direction they've been trying to go for five or ten years... through the too-small injector pathways.
Also -> Amazon link
sleddriver
sleddriver
Post by sleddriver » Thu Sep 15, 2016 11:12 am
M1 10W-30 HM
