850 Turbo 1996 Radiator removal
C@lvin
- Year and Model:
- Been thanked: 2 times
Bill,
The ECU tube has a nipple on the end that just pops out of a rubber liner in the hole in the shroud. If you pull the duct off at the other end (ECU end) first, then you can rotate the duct and pop it out at an angle to loosen it. This duct, in particular does get brittle with heat and age so it very well may crack, but you can't get it out without applying some force to it.
The intake duct should just slide out toward the rear. The accordian section should allow enough play to removed it, but if it's brittle, you may also want to remove the duct from the airbox end first.
Calvin
98 S70
00 V70
240,245,760,940,850 Turbo
98 S70
00 V70
When I did mine, I just pulled the ECU duct off at the ECU box end and left it connected to the shroud. FYI, the air duct pulls off the air box easily after you get the turbo pipes/hoses off, but be careful when you put if back. It fits around the outside of the duct that sticks out of the air box. Here's a photo of the shroud out the car.
1998 Volvo V70 AWD 165000-R muffler, HD endlinks, boost gauge
2008 Ford Fusion AWD 107000
2000 Ford Ranger 4wd 172000
1991 Toyota Camry 160000#1
Previous: 1982 Volvo DL (240) 160000
1998 Tacoma, Fords (6), Dodge, Montero,
GTO, Sunbeam Alpine, VW Dasher
- 940 Views
Last post by oragex
- 691 Views
Last post by Dave in Maine
- 2485 Views
Last post by yanga001
- 20 Replies
- 3801 Views
Last post by RickHaleParker
- 1300 Views
Last post by 94+96_850
