Tensioner Torque Specs
jakeizchillin
- Year and Model: 1993 850 GLT
I was wondering if anyone has the torque specs for the automatic tensioner. I found the pdf that shows how to take it apart for lubrication, but I am wondering how tight I should put everything back together. Thanks!
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
To convert Nm to ft-lbs multiply by 0.7375
- Has thanked: 17 times
- Been thanked: 35 times
I should have posted a reply when I saw this last night...but when I looked these specs up, I was amazed at how little torque is actually used on the TB parts, especially very little considering that I broke 2 tools trying to get the tensioner pulley off of my car. Anyway, good luck with your change.
jakeizchillin
Thanks vegasjetskier, but I was wondering about the accessory belt tensioner. Sorry! should have been more specific!
confused_al
- Year and Model: 1996 TLA wagon
MadeInJapan wrote: VADIS lists the following:
Tensioner Pulley: 30Nm (22 ft lbs)
Idler Pulley: 24Nm (17.75 ft lbs) (if re-using, make sure and grease the bushing in this pulley).
Auxiliary Belt Tensioner 20Nm (14.75 ft lbs) for both screws...also the same value if you remove the center screw of the tensioner to regrease the internals.
I always thought the VADIS values were a bit low and would nudge the bolts just slightly more than the listed values.
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
jakeizchillin
Thanks!
confused_al
You are welcome!
I asked the same question a while ago,
https://www.matthewsvolvosite.com/forums ... =1&t=17913
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
- 1745 Views
Last post by kosh_al
- 3568 Views
Last post by gibbi42
- 7552 Views
Last post by miticavolvo
- 3234 Views
Last post by draser
- 683 Views
Last post by williala
