MadeInJapan's post about how he solved his confounding PCV issue got me thinking. If a part sold in a kit -- in this case the intake gasket -- can be so seemingly unimportant yet so crucial, it's fair to say it's important to spend more when it matters.
What do you consider "no skimp" items?
Top Quality
Mann oil filters -- I think we can all agree on this (includes Volvo OEM which are rebadged Mann)
Cheap(er)
Spark plugs -- without getting into a sp debate, I think it's common knowledge that Champion and Bosch inexpensive copper plugs work well, and in some cases, extremely well in our inline 5's.
Which parts must be top quality? Which may not be?
- Has thanked: 2858 times
- Been thanked: 1332 times
volvomileage
- Year and Model:
agreed....
also top quality fluids motor oil to go with the mann filter..and tranny fluid....after all they are a direct cause to wear... the bougiecord sp wiring, tbelt 9continental oem ) and tensionners....
personally i wont gamble with a part if its tough as hell to replace or needs hours and hours of labour......
lower priced
blistein rear shocks great purchase
for the price and a decent muffler exhaust, and good quality engine mounts insted of the originals
lower priced
volvo 850 95 sedan non/turbo 185 k
^^^ You could be right, or it could be... both. A Google search for "OEM volvo oil fiter Mann" turns up 4500 results, and the same thing with "Mahle" turns up 5000 results.
MIJ will know
Whatever the case, I ran across this interesting study of German oil filter brands.
MIJ will know
- Has thanked: 17 times
- Been thanked: 35 times
I believe you're right- both. I'm pretty sure the insert type is Mahl though. In any rate, some things are better than OEM and so if you change out parts at all, go for the better (also cheaper)...ie: sway bar end links and spring seats for the struts (IPD sells a heavy duty version of each which is far superior). Where not to skimp? All Timing belt parts- don't buy the cheap stuff here- go OEM all the way... Belts, by Conti are fine but the hardware, get genuine Volvo. Also, don't buy the cheap stuff for the control arms (what the ball joints are attached to and included on) as these wear out quickly when they are not Volvo brand. Other than that, I can think of the Bouricord wires and Bosch MAF and 02 sensors (which are on Volvo's)...don't skimp on these. Otherwise, I guess you're pretty much either okay or limited to OEM parts. I could add that if you change out your vacuum hoses, you're better off (and much cheaper) to just buy silicone hoses from www.stylinmotors.com than to go to the dealer for rubber hoses by the meter.
volvomileage
- Year and Model:
filter debate ..
here's what i got after a quick research...
1995 Volvo 850 oil filter - 2.4
mann W 917 oil filter for 1995 Volvo 850 with 2.4 engine
Made by Mann+Hummel of Ludwigsburg, Germany with 41 locations worldwide
Mann is a certified OE / OEM supplier of these filters for Volvo
http://www.germanfilters.com/1994-volvo ... 46627.html
mahle on ther other side claims
More than 140 renowned engine and vehicle manufactures equip their engines with MAHLE engine components and filters as standard equipment.
This is a small selection of our customers:
....Toyota, Volkswagen, Volvo, Zettelmeyer........
probaly right volvo can have more than a supplier for filters...but most of the time mann is stated as the oem supplier 2 good choices anyway...
stone36
- Year and Model: 2005 V70R and XC90
RE: Oil Filters...
On my 94 850 (canister type) Mann is sold as the OEM...
On my 05 XC90 (cartridge type) Mahle is sold as the OEM...
So it probably depends on the brand, in other words
MadeInJapan wrote:I believe you're right- both.
05 V70R TiKap (so happy) 91K
05 XC90 2.5T FWD TiBlak 97K
94 850 wagon 2.4 (N/A) 155K (Sold running like a champ)
Will Robinson
- Year and Model: 850 1995
Mann is O.E.M canisters
Majle is for cartridge filters so im told by the ancient tech that services my 850
JRL
- Year and Model: Several
- Been thanked: 16 times
Suspension and hard to get to parts should be OEM
(Not springs and shocks)
Ball joints, control arms, spring seats and shrut plates and
inner and outer tie rods.
All the above should be OEM Volvo
I can believe that the Mann canister filter, does act as a check valve for the oil, but I'm not convinced any of the cartridges perform the same feature.
88 Volvo 760T
90 Volvo 760T
94 Volvo 855T
99 Volvo C70
04 Volvo V70
04 Volvo S60R
90 Volvo 760T
94 Volvo 855T
99 Volvo C70
04 Volvo V70
04 Volvo S60R
- 511 Views
Last post by misha
- 542 Views
Last post by tryingbe
- 21 Replies
- 5654 Views
- 3003 Views
Last post by xHeart
- 625 Views
Last post by firstv70volvo
