Thermostat bolts
AlanS
Been thanked: 2 times
Post by AlanS »
I am trying to change my thermostat on my 95 850. The torx bolt seems like it will strip if I turn it too hard. It seems ceased. Any hints on removing these bolts?
tailor
Year and Model: 2004 XC90 2.5T AWD
Post by tailor »
There is good write up on changing the thermostat in the repair database. A good dollop of PB Blaster or similar will normally give good results. If possible do this a few days before and running up to tackling the job. The torx socket/ driver is important as well. Now may be good time to flush the coolant .
1994 850 Auto Turbo wagon 306000km (Sold)
2004 XC90 AWD 188000km
"Life is like a reel to reel tape recorder,
the closer you get to the end,
the faster it spins."
Abe Gottschalk
Mike-Halewai
Post by Mike-Halewai »
I had to give my two torx screws a heck of a lot of muscle to get them out. I used a good set of high-end torx bits, almost stripped-out one of them, but each after enough muscle cracked loose.
Mike.
94 850 Turbo Wagon.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
A lot of PB Blaster, soaking overnight, and slow and steady pressure with the best quality torx bit you can find will help. Once they break loose they are easy.
Volvo found the error of their ways and they have coated steel bolts for around $1.00 each at the stealership. Have the new bolts on hand to replace the old ones.
