This is where you can add your additions to the 850 Trouble Code table.
Simply post a reply to this thread with the code(s) you're addressing, and any notes or links you want me to add to the table.
In a few hours (hopefully) Voila! They'll be on it.
Add to the Volvo 850 Trouble Codes page
- Has thanked: 2857 times
- Been thanked: 1332 times
- Has thanked: 17 times
- Been thanked: 35 times
Thanks Matt!
KRUZNBY
- Year and Model: '94 855T Wagon 117K
I think there are some discrepancies between this list and the factory service manual that could create some confusion. I found some in A2.
From the webpage:
From the webpage:
From the factory service manual:414 Boost pressure reduction from TCM
416 Temperature warning level 1
432 P0331 Rear knock sensor signal
433 P0331 Front HO2S slow response
435 P0133 (slow), Front HO2S slow response
414 Boost Pressure Regulation
416 Boost Pressure Reduction From TCM
425 (P0140) Temperature Warning Level No. 1
432 Temperature Warning Level No. 1
433 (P0331) Rear Knock Sensor Signal
435 (P0133) Front HO2S Slow Response
'94 855T Wagon (120K)= Boost and a booster seat all in one.
Stage 0 in progress...
Excellent find, thanks K. I'll figure out what to do with this.
- lext
- Year and Model: 1994 854
- Has thanked: 1 time
Some codes that are not on the front page yet:
Socket A-2 (fuel system)
511: Long term fuel trim lower limit at idling
512: Short term fuel trim lower limit
I actually got 512 right now and am not sure what to do about it. Someone somewhere mentioned this (possibly from the service manual?):
If the short–term fuel trim remains lean for more than 3 minutes and engine temperature exceeds 75°C (167°F), DTC 5–1–2 is set.
Not sure what would be the most likely cause. Aging fuel pump? Clogged fuel lines? Some sensor gone bad?
94 850 non-turbo
2011 S40 T5
2011 S40 T5
