We've changed the battery, starter, alternator, ingition switch; checked/cleaned the battery cables and ground connections, but the car still continues to have a problem starting with the same symptoms: clicking noise--almost sounding like a drained battery except it will start after cranking it 10 or so times...
Any ideas?
S80 2000 To start of not to start
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
How many miles on the car? Turbo or not? When were the spark plugs last changed? Fuel filter? Timing belt?
vegasjetskier
Did you reuse the old solenoid on the new starter motor?kmohnike wrote:134,000; all tune-up work and timing belt changed about 20K ago--It's not a turbo.
vegasjetskier
Does your relay/fuse block in the engine compartment look like this?
99volvo4life
- Year and Model: 1999 volvo s80
i have this same problam can u tell me whats wrong
I would guess that you have a bad starter or least the soleniod is bad. Check all connections.
Make sure the replacement battery is the right size and has the right cranking amps. I have had problems with the battery size being incorrect.
balah26
- Year and Model: sedan,s80 2.9l 2000
Have the same problem and i just fix it, these is how;-
[1]check or change your fly-wheel bcos once there is a crack or dent the contact with the ignition would be failing and starting would be hard. [the starting problem would be over.] pls try it is100% guarantee.
- 2026 Views
Last post by EngineeringBloke
- 1110 Views
Last post by Kram
- 5524 Views
Last post by ektrules
- 620 Views
Last post by treestone27
- 431 Views
Last post by FultonFamily
