Good day
My car is year end 1999 S70-2.0T , with 163 bhp and 230nm.
I think this model found only in Asia market. Not much info I get from net.
The weakest point is auto gearbox. Already rebuilt for three times. It's AW 50-42 LE which is 4 speed (without Sport / Economy mode)
I do read previous posting in this forum , but still have confusion about suitable ATF alternative. Forgive about bringing up this topic..again. For many years been using expensive orginal ATF. After the 3rd rebuilt, I give up using Volvo ATF, and now on Toyota Type IV .
Is 1999 AW50-42 compatible with Toyota Type IV atf ?
Thank you
ATF for S70
JDS60R
- Been thanked: 3 times
Your vehicle only requires Dexron3/Mercon. The issue is usually heat . The type IV toyota fluid you are using is not the correct fluid and is a bit too slippery for your transmission.
Switch the fluid to a full Sythetic Dexron3 mercon fluid - We suggest Amsoil ATF or a Castrol sythetic.
Also - Put a transmission cooler in line with the return line from the radiator.
Retired
- Has thanked: 17 times
- Been thanked: 35 times
Not to disagree, but actually Volvo recommends going to the type #3309 for 4 speed auto Aisin-Warner transmissions that are having issues... I've never tried it as I've kept with Mobil Synthetic ATF in my S70. I use Dex/Merc (Castrol) in the 850 as that is actually closer to the original spec.
Thank you
After the 3rd gearbox rebuilt & filled with Toyota Type IV ATF, I drive the car for 900 miles. Can feel the shifting is smoother. Atf level at dipstick also never get low and the color still maintain pink & clean.
Also during the 3rd rebuilt, I asked mechanic to fit extra ATF cooler. Good stuff to have , weather is hot here in Malaysia
Everything works fine so far. It really scare me to drive long distance because all the previous gearbox breakdown happened after long distance trips ( 8 hours drive).
Mobil 3309 is very difficult to get here. But there's Castrol ATF. Conoco's Super 76 Dex III is popular alternative here in Malaysia.
Thanks again
Thanks again
Toyota Type IV ATF = JWS-3309
It's the same thing!
JDS60R
I was unaware that Volvo had suggested the JWS-3309.
You should call a local transmission shop to ask if the fluid would do any damage. Or just call a Volvo dealership.
Best to use a synthetic or change often.
Glad to hear you have the transmission cooler
Retired
Yes, call Volvo if you wish...you can use 3309 in 4 speed auto transmissions but not the other way around (dexron in the 5 speeds).
Aaahh..
Glad to know I can use the Toyota Type IV ( 3309)
I can have good sleep tonight
JDS60R,
Yes..there's ATF cooler now. Many friends fit the extra ATF cooler long time ago on their T5s .
I guess,the original radiator cooler did not do well in hot climate..thus extra ATF cooler is good to have.
JDS60R,
- 11 Replies
- 11855 Views
Last post by STSCowboy
- 1143 Views
Last post by shiloh51933
- 739 Views
Last post by foggydogg
- 4448 Views
Last post by amblerman
- 3056 Views
Last post by boksalg
