94 850T getting tired
I was looking at potential, relatively cheap upgrades for my 1994 850 Turbo. The car has around 200k and has lost much of it's pep. Mainly looking to bring some life back into it, I've looked at both Air intakes (http://www.ipdusa.com/Volvo-850/Perform ... -143-3546/), or (Perhaps a remedy to my low boost pressure [gauge, though moving, never makes it into white zone]) http://www.ipdusa.com/Volvo-850/Engine/ ... -168-2155/. Any suggestions as to the most beneficial upgrades/changes to bring some of it's power back would be great, thoughts?
- Has thanked: 2864 times
- Been thanked: 1332 times
A chip is a good way to go fast for lots of money, while a manual boost controller (more MBC) is a less reliable way to go fast for little money, but whatever you do make sure your Volvo is up to Stage 0 first.
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
You might want to upgrade your Compressor Bypass Valve: http://www.quickbrickmotorsports.com/pr ... grade.htmlStevieb wrote:Perhaps a remedy to my low boost pressure
Hmm, never even heard of that! It seems to be the alternative to the familiar blow-off valve. I was poking my head around today but I can't seem to locate it looking into the engine bay, and have had no luck searching for volvo specific images. Based on the info in the link it would seem a car with as many miles as mine would very likely benefit from a new diaphragm. The MCB also seems promising; a performance chip is a bit too expensive. If I were to replace the air filter with the short ram should I expect any performance increase?
vegasjetskier
It's on the turbocharger compressor section.Stevieb wrote:I was poking my head around today but I can't seem to locate it looking into the engine bay, and have had no luck searching for volvo specific images.
- Has thanked: 17 times
- Been thanked: 35 times
I have a new insert for mine- if it wasn't just such a pain to get to to take it off.
- 1442 Views
- 1260 Views
Last post by oragex
- 12 Replies
- 4979 Views
Last post by brunocerous
- 1991 Views
Last post by FLXC90
- 708 Views
Last post by erikv11
