2001 V70 T5
Is there an easy and cheap way to up the pressure and by how much do you reccomend?
easy cheap way?
reinier claasen
- Year and Model: V70 t5 2001
2001 Volvo V70 t5 - K&N Air filter
- Has thanked: 17 times
- Been thanked: 35 times
If you're talking about tires, just add air.
If you're talking about the turbo, you can go with a manual boost control, but you have to watch out without a proper tune or you can do some damage.
reinier claasen
he he he.... Yes I meant the boost on the Turbo. You said something about a propper tune. Do I need to retune it after upping the pressure or what do you mean?
Tune means your computer really needs to either be software updated or a chip installed to take advantage of the higher boost... A manual boost control will up the boost but without the first, it is possible to detonate the engine...just a thought, but you probably can up things to about 15PSI without it doing that without a tune- You'll need an accurate boost gauge so you don't do any damage.
reinier claasen
Ok thanks. What is the psi standard on the v70 t5?
11 PSI without a chip or software upgrade.
It could be...was thinking of earlier model V70 T5's. Sorry, I don't have the numbers- maybe someone else does.
- 4284 Views
- 1555 Views
Last post by rguzz
- 8645 Views
Last post by ThommyKent
- 22 Replies
- 34674 Views
Last post by jmartin919
- 5817 Views
Last post by JenniferWatts
