'94 850 N/A died at stop and while running.
warrenout
- Year and Model: 850 1994, 2015 XC60
1994 850 n/a developed a problem. Backed out of drive-way and car died. Ran fine for the 40 mile commute. Started fine in parking lot, ran a few minutes and died and had problems re-starting. Once restarted, ran fine for the 40 miles home. This car runs like a champ normally. Not a miss nor a hiccup. What could be the problem? I removed the MAF sensor, cleaned with CRC and also cleaned the wire connector pins with CRC. Restarted an ran fine. Could this have been my problem?
- Year and Model: Many Volvos
- Been thanked: 76 times
Do you have any codes from port A-2? If so, post them back.
warrenout
I pulled codes:
131 - no rpm signal
241 - low egr flow
314 - no cam signal
Replaced cam sensor, fuel filter, spark plugs, dist. cap and rotor. Runs like a champ. Fuel economy has increased to 30+ mpg.
131 - no rpm signal
241 - low egr flow
314 - no cam signal
- Has thanked: 17 times
- Been thanked: 35 times
Thanks for posting back as to your solution.
I would have suspected cam sensor from your description.
It was good you did a tune-up at the same time!
- 4815 Views
- 110 Replies
- 17655 Views
Last post by bmdubya1198
- 1289 Views
Last post by FL850_1997
- 14 Replies
- 3479 Views
Last post by dj_v70
- 1147 Views
Last post by raykan
