I'm an old volvo mechanic (in my 60's and know all about the old volvos 122, 140, 240 stop!) I've recently been dragged into the '90s with a '95 850 wagon. I'm pleased thus far and am being sure that everything re preventative maint is up to date. Seeping oil at the usual spots indicates a clogged PCV system and sure enough the flame trap is plugged but I'm unsure of the procedure regarding the oil separator. How big a job is it? It doesn't look easy to get to. What's the best procedure any of you have discovered? Can it just be blown out or must it be removed and cleaned or replaced?
For any of you old Volvo fans out there try googling An Old Volvo song. TD
Oil separator; clean it or R & R it?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Somebody just clean pcv and flame trap and others replace whole pcv system including hoses.
To reach the pcv box,you need to take the intake manifold off.From that point everything is reachable and easy.
The signs of a clogged pcv system are oil all over valve cover,oil around oil dipstick,increased oil consumption,sometimes oil burning and smoke(positive pressure)from oil dipstick when engine is hot.All of these signs could also mean that engine have too much blow-by(worn engine).
So,everybody just clean or replace pcv system to know for sure that pcv isn't the problem.
Here is write-up how to do that...it's for turbo model,but procedure is almost the same:
http://lakesidedp.com/uploadpics/pcv/
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 734 Views
Last post by Olegs855R
- 1348 Views
Last post by 454cid
- 1027 Views
Last post by tlh
- 767 Views
Last post by Vvvvvvvvvv
- 1190 Views
Last post by Capndirk
