Stalling and hesitation, not from ETM
DonWillson
- Year and Model: 2000 V70XC
What else have we found that can cause stalling and acceleration jumps from 1800 to 2300 RPMs, other than the ETM?
Announcing my affiliation with XeMODeX, Inc. as Internet correspondent and consultant to Volvophiles needing help with failing ETMs. See http://FixYourETM.com. For the full history of this problem see http://VEXEDvolvo.org
Brucebo
- Year and Model: 850 '96, S70 '99
- Has thanked: 3 times
- Been thanked: 5 times
1. A mal-adapted fuel trim table (caused by bad sensors, etc. that are replaced but the trim table is not reset (by disconnecting the battery for awhile on S70s)). The fuel map should be seen as a smooth rolling snow covered landscape with no "moguls" or even worse, canyons or Matterhorns!
2. Poor electrical contacts in the connectors, especially the ETM. I was getting repeatitive surges and hesitations a couple of months after swapping my ETM. I was thinking of sending it back to XeMODex but I tried spraying contact cleaner on, and reseating, both the ETM and MAF connectors, then resetting the fuel trim and the problem instantly, completely and, at least for a month now, permanently went away. Compared to signal connections, the actuator on the ETM requires a relatively high current, so clean contacts are a must.
-Bruce
-Bruce
- 7719 Views
Last post by enriquepr21
- 24 Replies
- 3806 Views
- 23 Replies
- 8930 Views
- 5113 Views
Last post by antonevane
- 15 Replies
- 6859 Views
