Recently my left rear (passenger) door does not lock like the other doors when I lock the car (850 wagon) either with the key or the button on the key fob. Where do I start? Am I looking for a bad connection? faulty actuator? corroded ground?
Tom Demarest
Volvo Mech. Emeritus
My cars & Volvo ringtone at this link
<http://www.oregrownmusic.com/anoldvolvo.htm>
Non activating door lock
- Year and Model: Many Volvos
- Been thanked: 76 times
It could be any of the problems you describe. You need to start at the lock solenoid with a voltmeter and work your way back.
So there isn't a common point where leads branch off to each door-lock that's easily accessible? I was hoping to avoid taking the door panel off first thing.
Tom Demarest
Tom Demarest
- Has thanked: 17 times
- Been thanked: 35 times
The door panel is easy to get off and on...
Like Lee said, you'll have to get in there to see what's going on- most likely you'll need a new lock solenoid. I too have the same problem on my front driver's side door but it seems related to heat or direct sunlight on that particular door- after I've driven with the A/C on for awhile, it works again- seem I need to get into mine now- for now, I just use the key to lock it when it's not working with the FOB.
- 11 Replies
- 3132 Views
Last post by jonesg
- 16478 Views
Last post by precopster
- 1191 Views
Last post by Mike Langlois
- 1123 Views
- 491 Views
