S70 shifter knob removal,(manual stick)
Ragman
- Year and Model: 2012 XC70 T-6
How does one remove the shifter knob from a 98 S70 manual shifter without destroying it? I need to replace the ball cup on the shifter base. Thanks for the input.
86 740T M, 98S70T-5 M x2, 07 V70 2.5T
- Has thanked: 17 times
- Been thanked: 35 times
Not sure if this is what you wanted...but hope it helps:
Yet, another satisfied customer!
Juan62
- Year and Model: S70 T-5M 1998
- Been thanked: 2 times
MadeInJapan;
Do you have the instructions on how to remove the manual shift knob and leather boot? My boot is torn and needs replacement, even if i decide an aftermarket one.
Thanks.
Thanks.
98 S70 T5-M Brick for life
Juan62,
Mine is a 1994, 850. On that, the Knob simply pulls out but must be yanked pretty hard. Once that's done, you pull up boot the same way after releasing its bottom frame from the place where it fits on the console. (Matt01 has pictures of it) There are clips inside both the knob and the boot top but they're tension clips and don't need to be cut or anything (if it's like my 850).
- 7886 Views
Last post by oragex
- 946 Views
Last post by amblerman
- 14 Replies
- 3262 Views
Last post by bmdubya1198
- 733 Views
Last post by lummert
- 1354 Views
