'98 S70 Fuel door
Fuel door switch is not currently working. Need to get some gas in the tank, and can't find a way to open the fuel door. There is not a pull ring on the inside, which seems to be on the 850's, not the S70. Any suggestions?
IPD Sport Springs. Koni Yellows. IPD endlinks. IPD strut bar.
160,000 miles
160,000 miles
- Has thanked: 17 times
- Been thanked: 35 times
No ring, but pull the carpet out of the way and then reach in and right on the inside of where the door is, you'll feel the square piece of the latch...just pull it with your finger and the door will open. Mine does this periodically-- I find that if I lube the hinge part of the spring contraption, I'm good to go for another 6 months or so.
