My MPG gauge is very accurate
This topic is in the MVS Volvo Repair Database » My MPG Gauge Is Very Accurate
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2854 times
Been thanked: 1332 times
Post by matthew1 »
I've done two full tanks comparing mileage from trip odometer/math vs. the MPG computer. It's accurate to within a decimal place.
Also -> Amazon link
VCA
Been thanked: 5 times
Post by VCA »
matthew1 wrote:I've done two full tanks comparing mileage from trip odometer/math vs. the MPG computer. It's accurate to within a decimal place.
...and it will be, unless your fuel level sender goes ape, thinks "empty" occurs when you have 3 gallons left and starts throwing trouble codes :mrgreen:
2008 S80 T6 AWD
1999 S70 GLT
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
So is mine. :D
tjts1
Year and Model: 96 855 NA 5 speed
Been thanked: 4 times
Post by tjts1 »
Yup mine is also accurate. I pulled it at the JY from a 97 automatic and installed it in our 96 NA 5 speed. Its always within .2mpg of calculate mileage at the pump. I used to compare the two at every fill up but now I'm confident in the number the trip computer spits out.
No. The trip computer doesn't use the fuel level sender to calculate MPG. It uses injector pulse width vs speed. The car was designed to show empty at 3 gallons. When the tank is that low, you can starve the fuel pump in sharp turns. Its a safety feature. The reason fuel pumps die is because owners repeatedly keep driving after the low fuel light comes on.
Ambitious but rubbish
VCA
Post by VCA »
tjts1 wrote:No. The trip computer doesn't use the fuel level sender to calculate MPG. It uses injector pulse width vs speed. The car was designed to show empty at 3 gallons. When the tank is that low, you can starve the fuel pump in sharp turns. Its a safety feature. The reason fuel pumps die is because owners repeatedly keep driving after the low fuel light comes on.
Might be true on the 850s, but on the networked cars (post-99), the long-term fuel economy is reconciled with the fuel level difference over the last 100km. Otherwise, ECM-4050/DIM-0002 gets thrown and the trip computer (I assume) errs on the side of the lower figure. I know this because of the 6 months of throwing that code on my car and being 2+ MPG off (using the same gas pump and computing mileage between tanks). Replacing the sender made the figure agree with the computed economy :shock: . Oddly, the ECM is capable of throwing that code even if you don't have trip computer software installed.
2008 S80 T6 AWD
1999 S70 GLT
instarx
Year and Model: XC70 T6 2011
Has thanked: 1 time
Post by instarx »
Very timely post matthew. Just this morning I finished a 1,013 mile round trip. Except for 3 miles at either end it was exclusively interstate. Odometer MPG read 30.2, calculated mileage was 29.8. That's a difference of a little over 0.1%.
Around town however, the odometer usually under-estimates actual mpg by about 5-7%.
Incidently, last year I made the exact same trip but with a small front air dam. Measured mileage was 32.8. Apparently the air dam adds about 3 mpg at 65 mph. That seems high to me, but data are data.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Funny you should mention that. The best mileage I ever got on my '94 NA was when I bought the car and they had disconnected the rear spoiler and thrown it in the trunk due to a broken mount. Adding the rear spoiler back actually cost me about 1.5 to 2 mpg in terms of mileage with a lot of highway miles. We have a 65 MPH speed limit on the state highways but the highway patrol officers don't even blink until you are 10 over so I run 74 MPH on cruise without a lot of fear except for the speed trap towns that I know about.
I fixed the mounts on the spoiler and - at least for now - I am leaving it because the spoiler along with the Columba wheels makes the car look very sporty for a cruddy old 224,987 mile N/A that runs perfectly.
Do I get a grill badge for 225k? :D
bob850
Year and Model: 1996 850 Turbo wagon
Post by bob850 »
tjts1 wrote:Yup mine is also accurate. I pulled it at the JY from a 97 automatic and installed it in our 96 NA 5 speed. Its always within .2mpg of calculate mileage at the pump. I used to compare the two at every fill up but now I'm confident in the number the trip computer spits out.
A number of years ago, an indy mechanic who did a lot of work on Volvos, and drove an 850 himself, told me that I should fill up my 850 when I get to 1/4 tank, especially in summer. He said the "surrounding" fuel helps keep the pump cool and prolong its life. At the time, he had his car in the bay to replace his own original fuel pump, which had just failed at 190,000 miles. I'm not sure how accurate his advice was, but I tend to fill up shortly after I hit the 1/4 tank mark. Still on original fuel pump at 130K.
1996 850 Turbo Wagon - 175K miles, ARD Green ECU, Koni FSD, IPD sways, Snabb intake pipe, IPD HD TCV
1999 V70 T5M - 220K miles, M56H swapped, 2004 S60T5 engine, IPD sways, H&R springs, Bilsteins, TME catback, tune
2007 V70R, 55K miles, mostly stock
Has thanked: 1609 times
Been thanked: 4064 times
3 mpg for an air dam seems really high. Same fuel, temperature. warp core properly aligned?
Ive done some nasty Boston trips in the T5 where Ive ended up with 27 mpg instead of my 29 that I like to see - the good news is the AC hasn't hurt me when needed. Town driving Im doing 24-25 mpg.
I got 13 mpg last trip, but I had 2000# of boat behind me....that gas doesn't count.
osman
Year and Model: 2002 c70 hardtop
Post by osman »
We have the same car and thats about what I get, I just put on oem roof racks I wonder if that will effect my MPG's noticeably? I also have the rear spoiler on my 99 V70 T5.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
