Hello everyone,
I'm curios to know how difficult it is to replace the automatic shifter on a 1994 850 Turbo wagon. The old shifter doesn't look in great shape, I guess it is more of a cosmetic thing now that it is working perfectly fine. I'm guessing that all the shifters in the 850 Turbos are black, I'm not sure yet where to find a used one. Any help will be greatly appreciated. Thanks for reading my post.
Replacing automatic shifter
- Has thanked: 17 times
- Been thanked: 35 times
You can try a junk yard or eBay for a new shifter. After you turn the leather part that attaches to it 90 degrees and pop the boot off, you just pull like heck on the shifter and it will come off- it's sort of dangerous in that you can hit yourself in the face, or worse yet, go through the sunroof so be careful. I found, using an open spanner with something for leverage under the lowest section of the plastic shifter helps. Installation is just a reverse of that- keep pushing it down until it clicks into place- sometimes a rubber mallet helps. Good luck and let us know how it goes.
Thanks for your response. I guess my only question to this is how does the button that is pressed to shift from P-R-N-D-3-L engaged with the whole system? I just don't want to pull out the shifter and break a cable or something connected to that button. I will start looking for a new shifter and will let everyone know how does changing it goes. Thanks.
holmzee
- Year and Model: 1995 850 Turbo Wagon
Any luck on this? My shifter, while working fine is a mess- little rubber pebbles all over the center console area, it's getting annoying. I know I can find a replacement, I just don't know how big a deal it is to change. I haven't been able to find a write up on it.
Red-Arrow
- Year and Model: 850 T5 1995
- Been thanked: 2 times
I want to change the bulb as my wife needs to look down every time to change gear. Do I have to remove the whole center console.
Life would be enjoyable if it wasn't so painful to live.
JRL
- Year and Model: Several
- Been thanked: 16 times
Yes, takes 5 minutes if you know what you're doingRed-Arrow wrote:I want to change the bulb as my wife needs to look down every time to change gear. Do I have to remove the whole center console.
It's a special Volvo only bulb, about 12 bucks
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
'98 S70 T5
2016 Chevy Cruze Premier
- phils94850
- Year and Model: 2009 s60 turbo
Well.. not exactly the same..
On a 850.. once you remove the two rear bolts under the little cover in the arm rest area, there is two bolts to remove the little storage area under the ash tray, remove the storage opening, and under that theres two torx bolts that hold the front of the console in place, remove those, then you can lift it up the console and outta the way...
Ask me how i figured this out.. well i didnt remove the two front bolts on the console and cracked the wifes
1996 Platinum Edition
- 7978 Views
Last post by oragex
- 833 Views
Last post by R-CAMPO
- 13 Replies
- 2551 Views
Last post by smoggyama
- 1507 Views
Last post by rspi
- 1941 Views
Last post by greentrout
