I have a bulb out in the instrument cluster on my 2001 S60. How do you get to the bulbs to replace one? Can the instrument cluster be removed? Thanks.
Frank
Instrument Panel Bulb Replacement 2001 S60
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
This has to be one of the easiest to get out.
Switch off ignition and remove the key. Wait 1 minute after removing the key before going any further.
Remove the surround for the combined instument panel by pulling it straight out.
Remove the 4 screws.
Remove the connector.
Remove the combined instrument panel.
Install in reverse order.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
Hi Bill,
Will the process you outlined for a S60 2001 work for a XC V70 2001? It appears the perimeter shroud, which surrounds the instrument panel, can be removed with a even tug as clips seem to be holding it in place.
Appreciate the insight.
Chris
Chris
Yes, same for XC70. To facilitate removal of the instrument cluster you need to lower the steering wheel and remove the top plastic and rubber cover from the steering column, it just pulls off. Then remove the 4 cluster holding screws, and you can unplug the single plug in the back. Not easy to find the little instrument lights, they are actually of 3 different wattage, depending on their location, as designated by the different colors of their plastic housing.
I replaced the lower ones with the highest wattage variety to see the digits and numbers better on sunny days.
Eldad
Eldad
volvoesprit
- Year and Model: 2001 V70 XC
Hi Eldad, I have removed the top plastic/rubber cover above the steering wheel = real easy as you said and thanks.
But cannot see the 4 cluster holding screws? Where will I find them? I see two nut/bolt type but looks like they are securing something else to the steering wheel. Please advise and pics if you have them
Many thanks,
Michael
Many thanks,
Michael
- billofdurham
From VADIS. Ignore the last part about software.
Bill.
Bill.
Previously:
Previously:
volvoesprit
Bill,
Thanks mate and got your email too. Am glad this is simple enough as the other instructions were for the previous model and it looked complicated! Thanks again. Cheers
Griffithfamily09
- Year and Model: 08 s60
Will this work on a 2008 s60? And can you tell me what replacement bulbs I need to order?l for the culuster??
