850 turbo 1996 vibration damper guard
rnicolas
Year and Model: 850 turbo, 1996
Post by rnicolas »
I noticed with the vibration damper guard that the bolts are very close to the timing belt. Is this to prevent the belt from jumping?
rnicolas
Post by rnicolas »
I guess nobody noticed how close these bolts are to the timing belt!
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
I have read your post several times but I can't figure out what bolts your are referencing.
Do you perhaps have a picture that you can post?
rnicolas
Post by rnicolas »
The bolts that hold the vibration guard in place.
THe bolts only have a bit of threads.
rnicolas
Post by rnicolas »
There is plate that wraps around the bottom of the crankshaft.
It is held in place by two 10mm bolts.
I had to remove this to get my belt off.
The end of the two bolts are very close to the timing belt.
About 1/16 of an inch. Is this normal. I guess I am worried that the end of the bolt might scrape the belt and tear it.
Post by Ozark Lee »
Those are by design and, if the timing belt is properly installed, you have nothing to fear. I think they did design them to be close to try to keep the belt on if the tensioner fails. I must kinda work, I had a failing tensioner on my '94 but between the plastic spacer on the tensioner and those bolts the belt never jumped. Obviously I parked it once I discovered the problem though.
