1995 940 turbo accessing the A/C fan speed switch
Is there an easy way to access the rotating fan speed switch from under the bottom if the radio has been removed? if not, how much stuff has to be pulled off to get to it? Thanks Clay
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
You shouldn't need to remove the radio.
Have your radio code handy and disconnect the battery negative lead. Remove the trim panel around the heater control unit to expose 4 or 6 screws. Remove the screws and lift the control panel upward and outward. Disconnect the electrical connectors.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- 13 Replies
- 1411 Views
Last post by vtl
- 599 Views
Last post by sventhemeatball
