I have a 1998 V70XC and the fuel guage has stopped working. Any ideas as to what I might check. It started out working after driving for a while but now it has stopped working and I dont want to run out of gas during the morning commute and have the world upset with me for running out of gas
Fuel Guage not working 1998 V70 XC
Hi,
on the highway. Thanks
FCPEURO
- Year and Model: 2006 XC90 V8
- Been thanked: 19 times
Is the trip computer still calculating the miles until empty? If it is, then it is probably just the gauge itself and the low fuel light will still come on at 50 miles till empty.
If it is not computing the miles until empty, then you will need to replace the sending unit in the gas tank.
how long as this been happening? forgetting to turn the car to the accessories only or off position when fueling can mess up the way the car reads how full the gas tank is. just a thought.
1998 S70 T5 SE 214,001
1999 v70R 126,000
1999 v70R 126,000
mygoatboy
- Year and Model: 1998 V70 XC
I have the same problem on my 1998 V70 XC. I just had the fuel pump (which includes one of the two sending units) and it did not fix the problem. My mechanic tested both sending units and they were functioning perfectly. He then tested the gauge from the Volvo diagnostic system and the system could move the fuel gauge, so he said there is a connection problem somewhere in the car. The gauge had worked some of the time before stopping completely. A good wiring diagram would be helpful. The fuel pump/sending unit will run you $300-$600 depending on where you get it from and expect at least 9 hours of shop labor to do the job.
- Year and Model: Many Volvos
- Been thanked: 76 times
Here you go.A good wiring diagram would be helpful
http://pliki.mojevolvo.pl/volvotechinfo ... n_3_39.pdf
The site is in Poland and it is very slow. The schematics are in English.
- 1732 Views
Last post by ajr91
- 365 Views
Last post by shaker_chi
- 720 Views
Last post by lummert
- 127 Views
- 792 Views
Last post by 93Regina
