currently i see a ton of different octane ratings and a ton of different oppinions on it, some people say it doesnt help performance at all, some say it does,
im just wondering whats the difference between 87 octane to the 94 stuff, performance? better on engine? better for fuel filter?
besides the price difference heh
thanks again guys
Fuel Octane
This explains octane, directly from the oil company.
http://www.shell.ca/code/motoring/encyc ... ctane.html
petershen1984
- Year and Model:
If this is accurate as a rule of thumb, cars with compression ratios of over 10:1, or if the engine is turbocharged, then the premium grade is required, because this "compression" is what causes lower-graded fuel to ignite before actual spark.
Knocking/pre-ignition wastes power because, while the piston is being pushed up naturally in the cylinder, the preignition pushes the cylinder down before it reaches the top. Consequently, the piston is forced to "knock" on the sides of the cylinder walls, which makes the sound we hear typically when the engine is under a workload (climbing hills, with more passengers).
Peter Shen
1992 Volvo 960 (Silver)
Knocking (detonation) and pre-ignition are two different and unrelated things. The result sounds the same but the damage caused by knocking is different than that caused by pre-ignition. Typically knocking breaks things (like rings or ring lands) while pre-ignition melts things (like spark plugs and piston crowns).petershen1984 wrote: Knocking/pre-ignition wastes power because, while the piston is being pushed up naturally in the cylinder, the preignition pushes the cylinder down before it reaches the top. Consequently, the piston is forced to "knock" on the sides of the cylinder walls, which makes the sound we hear typically when the engine is under a workload (climbing hills, with more passengers).
The pinging or knocking sound you hear is not physical contact between the piston and the cylinder wall (which would quickly result in a ruined piston) but the sound of the pressure wave from colliding flame fronts hitting the piston...yes the impact from that pressure spike is loud enough to be heard.
If you want a very indepth article about detonation and pre-ignition, follow the link below:
http://www.streetrodstuff.com/Articles/ ... /index.php
It's 8 pages long and technical...but well worth the read.
pump prices here are $2.40 for "regular" and $2.60 for "premium" ... I usually put in 15 gallons of this overpriced low grade ripoff excuse for fuel at the time ... so that's $36 for the cheapest stuff they have or $39 for the best available ... that's less than 10% difference and the car drives better, idles better and gives me that tiny little bit of peace of mind that I'm doing the best I can to keep my Volvo's engine healthy ... why would I save $3 and run 87 through my car ? and someone is going to have to explain to me why 89 costs as much more than 87 as 93 does over 89 ... is that new math or something ? ... did you know that when a nuclear device is detonated over sand it produces green glass that glows in the dark ? what a neat effect !
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
Because of the 2 knock sensors in our engines, most of us cannot tell when the engine requires a higher octane. But, if you keep track of gas mileage from tank to tank, and have a turbo, you will be able to determine which grade is best for your driving style.
When the engine management computer detects knock, the timing is retarded until the knock goes away. This is how cars "determine" what grade of gasoline you use.
If you have a turbo and occasionally use the turbo, the 89 octane will probably work. If you like to put your foot in it a lot, then 91+ is for you.
For those readers not in the USA, our octane ratings are different than yours. Our 91 rating is about the same as 98 in Europe.
Klaus
Klaus
Klaus
- 1735 Views
Last post by MadeInJapan
- 56 Replies
- 16787 Views
Last post by vovo850
- 12 Replies
- 10606 Views
Last post by zanzabar
- 2280 Views
- 1193 Views
