Hello - I am planning on replacing my oil trap and the process looks straightforward except for the fuel line connection on the injector rail. Do I need a special tool and will I need to replace the connector once I take it apart?
Thanks.
v70 awd se 2000 fuel line connection at intake manifold
dusty
- Year and Model: 2000 V70XC, 1997 850
Hi, when I did this job, I carefully unbolted and pulled the fuel rail with the injectors and fuel line attached away from the intake. Now it is possible to rotate the fuel line at the big silver colored fitting and unbolt the torx screws from the bottom of the fuel rail. Slide out the plate that locks the fuel fitting and the injectors to the rail and carefully wiggle the fuel fitting out. When reassembling, a thin coat of Vaseline, or similar on the the injectors and fuel line seals helps everything go back together nicely. The toughest part of that project for me was getting the fuel line routed through the intake manifold correctly, take pictures of your engine before getting it apart, i know that helped me.
- 3402 Views
Last post by darylrobert
- 1556 Views
Last post by erikv11
- 759 Views
Last post by JimBee
- 729 Views
- 1165 Views
Last post by precopster
