94 850 NA cut-out
2goldvolvos
Post by 2goldvolvos »
About one year ago, with daughter #1 at the helm, our 94 850 cut out, showing the full Christmas tree. She was able to immediately restart, and all was fine. I quickly purchased a new fuel pump relay and slapped it in.
Yesterday, now with daughter #2 driving, the same thing (I think) happened. It seems unlikely that the one-year-old fuel pump relay is bad, right? Anything else to consider? Key switch?
Driving used cars so the kids can go to college
03 VW Jetta GLI 24v VR6
90 Volvo 740 GLE 16v
94 Volvo 850
akitawagon
Year and Model: 1997 855R
Post by akitawagon »
Was the fuel filter also changed when you replaced the fuel pump relay?
1998 V70 T5 223K
1997 855R 215K
1997 855R 124K KIA... distracted driver on phone
1997 855 T5 141K KIA... water pump
1996 850 GLT 160K
1995 855 GTA 325K KIA... distracted driver on phone
1993 850 GLTS 201K KIA... t-boned
volvomileage
Post by volvomileage »
well....
any codes ?
one thing i would check is fuel pressure at the end of fuel rail presure should be over 40 psi..
+ 1 if fuel filter has not been changed in a long while
in my case a loose ignition switch caused irregular problems but never has the car cut out but its a possibility if its really gone if you can wiggle the key a long way its time for a new one its a cheap and relatively easy part to change...
in my case...and i think i had my fair share of cut outs the causes were loose battery terminal clamps (even if it seems odd contacts have to be clean and the connectors tight..my car stalled in the middle of nowhere and restarted after being towed the terminal connectors were a bit loosse) bad fuel pump ( unconstant fuel pressure) fuel pump relay, camshaft sensor and bad maf ...
hope it helps
volvo 850 95 sedan non/turbo 185 k
2goldvolvos
Thanks for the replies. No, I did not change the fuel filter. It could be 15 years old! I'll check the batt terminals for tightness. About a month ago I did replace the OE stereo headunit with a contemporary aftermarket box. Maybe I didn't fully secure the negative.
94 Volvo 850
