After reading the forums related to my stalling problem, I pulled the codes from the car and got one code-P0103. I have cleaned the sensor with spray cleaner. Will that clear the code, or do I have to clear the car's codes through my ODB-2, or get a new MAF sensor to clear the code? With engine running, I can unplug/plug MAF sensor and hear a stutter. My wife drives the car more than I, and states the stalls happen at stoplights/stopsigns, more likely with the AC on, but starts right away after. When it stalls, pushing on gas pedal feels like pushing more air than gas. Car has 185k.
Thanks, what a great site!
850 Turbo 1996 MAF sensor-P0103
- Year and Model: Many Volvos
- Been thanked: 76 times
The easiest way is to clear it with the code reader and then see if it comes back.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
If you have a returning code which indicates bad Maf sensor,i'm affraid that it needs to be replaced.
If you're going to replace it,just make sure to replace it with original one(new one or used one).Don't buy any aftermarket Maf sensor.
Bosch is oem and it's number is 0 280 217 107.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 4751 Views
- 1856 Views
Last post by precopster
- 2434 Views
- 1303 Views
Last post by Soloarmadolo
- 1420 Views
Last post by Pistol Pete H
