850 1995 BATTERY LIGHT
- misha
- Has thanked: 155 times
- Been thanked: 432 times
You should have battery cables(+ & -)disconnected before reconnecting that wire!I'm assuming that you're talking about big red wire from the alternator.
If that loosen wire,in any case,touch chasis or any metal part in that area,complete installation in your car can be ruined in a split of a second.Sometimes it can set a car on fire.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
It shouldn't be hot.It may be that your cable have high resistance.
Are your battery cables dirty or coroded?
If they are,clean them up with alcool and teeth brush,and clean all grounds also if they are coroded.You can also use wd-40 for cleaning.
Could be that your cable is being hot because positive and negative cables are coroded and they are making high resistance and because of that they are hot.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 1343 Views
Last post by misha
- 1918 Views
Last post by jreed
- 3969 Views
Last post by mecheng
- 26 Replies
- 2163 Views
- 4536 Views
Last post by JacksonTNTurbo
