98 s70 window goes up but not down ????
solo1
Post by solo1 »
i got 98 s70 window goes up but not down i replaced the motor in the door but its the same could it be the master switch ?
JDS60R
Been thanked: 3 times
Post by JDS60R »
Yes- It could be the master switch or the wires leading to th motor.
If you hae an electrical tester (meter) you could test the plug at the motor and see if you are getting a signal from the switch for both up and down.
Retired
solo1
Post by solo1 »
i did and yes its there one wire lights up a little brighter then the other but the 12v is there that why i tried the motor first on the door but still the same
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
I hate to tell you this, but you've just worked way too hard and
probably broke a few door panel clips for pretty much nothing.
The switches in these cars are NOTORIOUS for going bad.
The motors, however, will probably outlive the car.
The way a window motor works is based on reversing polarity to the motor
on the same two wires. One polarity makes it go up, switch polarity and
it goes down. If the window moves at all, up or down, the motor is fine.
It may be the local switch ( the one in that particular door), but it's
most often a bad master switch. You can take a crack at cleaning the
contacts in the switch, but it's just a short term fix. Get to shopping!
You can get aftermarket or "repaired" switches for less, but I'd strongly
reccomend just getting an actual Volvo replacement and be done with it.
Call these guys for a baseline price on a real one:
DW Volvo / Parts Dept
(800) 689-0021
Ask for Don or Jamie
The best part is, you can pop that switch pack out from the top.
Replacement takes about two minutes. And no broken clips!
Best of Luck! :wink:
