96 850 code p0140
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Try to clean it up with carb cleaner.It might work.
If not,you can always buy a new one and always go with oem Bosch.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Code book says this:
Po140 rear heated oxygen sensor (Ho2s)aging...signal too high,intermittent fault.
So...because of intermittent fault,it could be connectors.Check them,and if they are ok,try to clean the sensor.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Year and Model: Many Volvos
- Been thanked: 76 times
On many there was a recall to add a jumper harness on the rear sensor - double the connectors and you double the opportunity for a bad connection.
- 39 Replies
- 8800 Views
Last post by DARK_BLU
- 1531 Views
Last post by E Showell
- 688 Views
Last post by snowisgr8
- 2301 Views
Last post by adamdrives
- 1132 Views
Last post by theWIFES_S70
