2000 V70 xc 110,000 mi. Timing belt at 103,000 (replaced)
Alternator has apparently failed, no charging voltage at battery terminals.
Fuses O.K. The warning lamp lights when the ignition is turned on but did not warn me of failure.
Can anyone tell me the proper procedure of changing the alternator. And does the warning lamp have a fuse (location) and does it need to be working to charge the battery. Anywhere I can get a wiring diagram?
Thank You
Dax
alternator problems
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
How's the voltage AT the alternator at idle?
(Go with an alternator case ground for your measurement)
Bad cables can be a problem with charging...
- Year and Model: Many Volvos
- Been thanked: 76 times
I'm scratching my head kinda like BEJinFBK is. If the alternator fails the light should come on.
As far as schematics go, here is a link:
http://pliki.mojevolvo.pl/volvotechinfo ... n_3_39.pdf
Be very patient, the site is in Poland and it is on a slow server. The schematics are in English.
I had a repair shop to confirm the alternator was not charging.
They said that I was not sending a signal through the warning lamp wire.
Their price to fix was unrealistic.
The tensioner is in tight quarters but probably accessible. Looks about 14mm. I assume that loosens counter clockwise.
I will double check at the alternator.
Thank You
Thank You
JDS60R
- Been thanked: 3 times
HI,
Here is the procedure you requested. Let me know if you need anything else. - Email and phone are fine.
Let us know if this helped.
2000 V70 XC Alternator removal.pdf- (66.54 KiB) Downloaded 174 times
2000 V70 XC Accesory belt removal.pdf- (133.81 KiB) Downloaded 153 times
2000 V70 XC power steering pump removal.pdf- (242.12 KiB) Downloaded 224 times
Retired
SilverS70
- Year and Model: S70GLT-SE 2000
Dax,Dax wrote:I have the downloads. This certainly helps.
Thanks to everyone.
Dax
I'm in Chicago too. Please let us know how you resolve this. Don't be afraid to take a few pics and share them with us so the next person can learn from your experience. It helps us all. Thanks.
2000 S70 GLT-SE 161,000 Miles, original owner.
